WidgetRTC not syncing - starts with 1970
Hello!
I have two Wemos D1 Minis with attached DHT22 sensors which sends temperature and humidity to my Blynk app.
One of the D1 stops sending data after some time - the code is identical. So I decided to add a “timestamp” for each D1 Mini by sending the actual time to a virtual pin - if this time does not change, the sensor stopped working.
The problem: The RTC time starts with 1970 and nevers syncs. I already tried different codes and even the example code shows “1970”…
Do you have a solution? I am on holiday now and wanted to leave the sensors in the holiday home to control the temperature…
Attached also a screenshot of my Blynk app:
Many thanks in advance!
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <DHT.h>
#define DHTPIN 4 //pin gpio 12 in sensor
#define DHTTYPE DHT22   // DHT 22 Change this if you have a DHT11
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "4Llxxxxxxxxxxxxxxx";  // Put your Auth Token here. (see Step 3 above)
WidgetRTC rtc;
  dht.begin();
  rtc.begin();
  Blynk.begin(auth, "WSHxxxxx", "maxxxxxxxxxxx"); //insert here your SSID and password
  Blynk.syncAll();
  setSyncInterval(60000);
  timer.setInterval(60000L, sendUptime);  // Update alle 60 Sekunden
void sendUptime()
  float h = dht.readHumidity();
  String currentTime = String(hour()) + ":" + minute() + ":" + second() + ", ";
  String currentDate = String(day()) + "." + month() + "." + year();
  Blynk.virtualWrite(16, currentTime, currentDate);
  Blynk.virtualWrite(12, t); // virtual pin
  Blynk.virtualWrite(13, h); // virtual pin
The rtc has to get the time from the Blynk Server. Therefore, the function rtc.begin() must be called after the board has connected to Blynk Server, by using BLYNK_CONNECTED() function. Otherwise, the time will start from Jan 1st 1970. The same rule will apply to other functions such as Blynk.syncAll(), etc.
You can change the program to something similar to the following code (which uses the better BlynkTimer, and optional Blynk_WM)
#define USE_SPIFFS    true
//#define USE_SPIFFS    false
//#define USE_BLYNK_WM    true   // https://github.com/khoih-prog/Blynk_WM
#define USE_BLYNK_WM    false
#define USE_SSL     false
//#define USE_SSL     true
#if USE_SSL
  #include <WiFiClientSecure.h>
  #if USE_BLYNK_WM
    #include <BlynkSimpleEsp8266_SSL_WM.h>     // https://github.com/khoih-prog/Blynk_WM
  #else
    #include <BlynkSimpleEsp8266_SSL.h>
  #endif
#else
  #if USE_BLYNK_WM
    #include <BlynkSimpleEsp8266_WM.h>      // https://github.com/khoih-prog/Blynk_WM
  #else
  #endif
#endif
#if !USE_BLYNK_WM
  //BLYNK AUTHENTICATION TOKEN
  char auth[] = "******";
  // MY WIFI CREDENTIALS
  char ssid[] = "****";
  char pass[] = "****";
#endif
#include <DHT.h>
WidgetRTC rtc;
BLYNK_CONNECTED()
  rtc.begin();
  //synchronize the state of widgets with hardware states
  Blynk.syncAll();
  Serial.begin(115200); // See the connection status in Serial Monitor
  dht.begin();
  #if USE_BLYNK_WM
    Blynk.begin();
  #else
    Blynk.begin(auth, ssid, pass); //insert here your SSID and password
  #endif
  timer.setInterval(10000L, sendUptime); // Update alle 10 Sekunden
void sendUptime()
  String currentTime = String(hour()) + ":" + String(minute()) + ":" + String(second());
  String currentDate = String(day()) + "." + String(month()) + "." + String(year());
  Blynk.virtualWrite(V16, currentTime);
  Blynk.virtualWrite(V15, currentDate);
  Blynk.virtualWrite(V12, t); // virtual pin
  Blynk.virtualWrite(V13, h); // virtual pin
@Hans5546 please edit your post and add triple backticks at the beginning and end of your code so that it displays correctly.
Additionally setSyncInterval(t) accepts the interval “t” in seconds, so, 60000 is too much (16.66 hours) , you may want to reduce it
I’m still trying to find a good solution to this sending out Jan 1970 the first time:
BLYNK_CONNECTED()
rtc.begin();  // Synchronize time on connection
serial_print_date_time();
Serial.println("Blynk server connected");
void serial_print_date_time()
char date_time [22];
sprintf (date_time, "%02d/%02d/%04d @ %02d:%02d:%02d ", day(), month(), year(), hour(), minute(), second()        );
Serial.print(date_time);
I thought about while year == 1970 in BLYNK_CONNECTED() but don’t want the whole sketch to hang just because of the time, a delay would be no good either. Maybe a millis function would be best?
Hello!
Many thanks for the replys! Especially to Khoih - your code was working without any changes :slight_smile:
One interesting thing: with my old code the time adjusted itself on the next day (maybe after 24h runtime?). But with khoih’s code the time was instantly correct.
And it was absolutely necessary to have the RTC widget in the blynk app! Without it, the time did not sync - maybe this is what 877 needs?
I modified khoih’s code a little bit to restart the esp automatically once a day. I will post the code later.
