Widget Graph in ESP8266 project
is there any problem with wiget Graph for ESP8266 platform?
I placed the Graph to the project page but I coud’nt edit it.
Also it blocked the operation of other widgets and I could’nt remove widget (no edit).
Graph disappeared (and 400 points) after the entry to project settings.
Now the project is working properly again
I would try again put this widget but I’m afraid to lose another 400 points.
I use BLYNK android version 1.12.2
I tried again - now is good
But 400 points is’t :slight_smile:
over out.
Should work. Points should be returned also. It could be just display bug and logout-login may update points.
thx
12345678901234=20 char
