Why is the Notification widget so large?
You cannot interact with the Notification widget on the dashboard, yet it takes up a lot of space that I could use for something else that currently does not fit. Is there a reason it has to be so large? Would be great if it was smaller, or even better hidden altogether.
RD7
I had a similar thought about the RTC. I wasn’t thinking about the size, specifically, but its very presence on the dashboard. It doesn’t really serve a purpose. Is there a way that you could make these “background service” widgets active without being physically present on the dashboard?
