Whenever I change V11 and V12, they are printed correctly in the terminal but whenever I change V8 between 1 and 0, both values are always printed as zero. But when I change V11 and V12, they still print correctly. It’s as if they aren’t speaking to each other. Why is this and how do I fix?
My code:
BLYNK_WRITE(V11){
float homeAngle = param.asFloat();
Serial.println(homeAngle);
BLYNK_WRITE(V12){
float awayAngle = param.asFloat();
Serial.println(awayAngle);
//TimedInput
BLYNK_WRITE(V8)
if (param.asInt()==1)
float adjustedHA = mapfloat(homeAngle, 68, 90, 170, 40);
servo.write(adjustedHA);
int tempDisplay = mapfloat(servo.read(), 170, 40, 68, 90);
Blynk.virtualWrite(V0, tempDisplay);
//Serial.println(adjustedHA);
float adjustedAA = mapfloat(awayAngle, 68, 90, 170, 40);
servo.write(adjustedAA);
//Serial.println(adjustedAA);
Please edit your post to add triple backticks at the beginning and end of your code so that it displays correctly.
Once you’ve done that we’ll explain your error to you.
You have to declare float homeAngle and float awayAngle out of the function.
float homeangle , awayAngle ;
I did that! I have them set as global variables and the issue still persists. I also tried to have the adjustedAA and adjustedHA as global variables and I’m still getting the same thing. It’s only in the longer if statement that I get a zero and I really am baffled.
Here is my updated code:
float homeAngle, awayAngle, adjustedHA, adjustedAA;
BLYNK_WRITE(V11){
BLYNK_WRITE(V12){
//TimedInput
BLYNK_WRITE(V8)
When I change V11 and V12, I get the proper readings in the terminal, but when I alter V8 I get a zero when I change to 1 or 0. Here is what the terminal looks like:
68.00
170.00
89.00
45.91
90.00
40.00
0.00
0.00
WOW oh my goodness…You are a genius! Can you maybe explain to me why that ruined it so I can never make that mistake again?
because when you declare float in the function, homeangle is local and not global, which resets the homeangle variable.
Thank you very much! This means a lot!
You are welcome my friend
