Why I am not receiving an Email from blynk to extract data, and why there is no data been saved only live data shows
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
WidgetLCD lcd(V2);
char auth[] = "WLCQTwSjJfyPxlotDnqYoTEgPreyNwRJ";
char ssid[] = "MUBARAK";
char pass[] = "smile1234";
String myString; // complete message from arduino, which consistors of snesors data
char rdata; // received charactors
String voltage;
double Power;
double Energy;
double m1=7.2;
double m2=0.2;
int firstVal;
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent()
  Blynk.virtualWrite(V1, millis() / 1000);
    timer.setInterval(1000L,sensorvalue1);
   if (Serial.available() == 0 )
  if (Serial.available() > 0 )
    rdata = Serial.read();
    myString = myString+ rdata;
   // Serial.print(rdata);
    if( rdata == '\n')
Serial.println(myString);
// new code
voltage = getValue(myString, ',', 0);
Power = m1* voltage;
Energy = Power * m2;
  myString = "";
// end new code
void sensorvalue1()
    lcd.clear();
    lcd.print(0,0,"   Magic Mat      ");
    lcd.print(0,1,"Voltage=");
    lcd.print(8,1,voltage);
    lcd.print(10,1," V ");
    Blynk.virtualWrite(V3, voltage);
    Blynk.virtualWrite(V4, Power);
    Blynk.virtualWrite(V5, Energy);
String getValue(String data, char separator, int index)
    int found = 0;
    int strIndex[] = { 0, -1 };
    int maxIndex = data.length() - 1;
    for (int i = 0; i <= maxIndex && found <= index; i++) {
        if (data.charAt(i) == separator || i == maxIndex) {
            found++;
            strIndex[0] = strIndex[1] + 1;
            strIndex[1] = (i == maxIndex) ? i+1 : i;
    return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
I’d try writing integer or float values to V3, V4 & V5 instead of strings.
