Oh my good I have checked and tested now, and the problem was as i suspected. I had not connected the ground from Wemos to the ground rail on breadboard.
With your current code that uses the Blynk.syncVirtual(V1);
this will not be the case. As you are essentially just setting the button to off, then triggering the command that would simulate manually pushing it. I would maybe try the approach of deleting the timer if the button is pressed before it finishes.
int coffeeTimer;
void coffeeOFF() {
Blynk.virtualWrite(V1, LOW); // Sets the virtual pin state
digitalWrite(coffeeSwitch, HIGH); //Turn OFF Coffee
digitalWrite(yellowLED, LOW); //Turn OFF Yellow LED
digitalWrite(greenLED, HIGH); //Turn ON Green LED
BLYNK_WRITE(V1) {
int pinValue = param.asInt();
if (pinValue == 1) {
digitalWrite(coffeeSwitch, LOW);//Turn ON Coffee
digitalWrite(yellowLED, HIGH); //Turn ON Yellow LED
digitalWrite(greenLED, LOW); //Turn OFF Green LED
coffeeTimer = timer.setTimeout(5000L, coffeeOFF); //Start coffeeOFF Timer
if (pinValue == 0) {
timer.deleteTimer(coffeeTimer); //delete CoffeeOFF Timer
P.S. Adding comments to your code can help with troubleshooting, and helps others when trying to troubleshoot.
¨Thanks alot Toro_Blanco!
That code worked perfectly.
Here is my working code so far. I’m going to build it out a little more i think, but now i have a little more meat on my legs
//Put WiFi cridentials and token here----------------------------------
char auth[] = "*******";
char ssid[] = "*******";
char pass[] = "*******";
int coffeeSwitch = 5;
int yellowLED = 4;
int greenLED = 13;
int coffeeTimer;
pinMode(coffeeSwitch, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(greenLED, OUTPUT);
BLYNK_CONNECTED() {
void LEDtimer(){
digitalWrite(greenLED, LOW); //Turn ON Green LED
void coffeeOFF() {
Blynk.notify("Kaffen er klar! PS! Trakteren vil så seg av automatisk etter 10 minutter.");
timer.setTimeout(5000L, LEDtimer);
BLYNK_WRITE(V1) {
