Why blynk is not working proper after an email is send out, i cannot control the sensor example like on/off fan,on/off light, but sensor dht-11 still can working as it keep updating the data to my blynk.
raspberry pi 3 + internet
Android
Blynk server
from gpiozero import LED
import RPi.GPIO as GPIO
import BlynkLib
import time
import Adafruit_DHT
import sys
from blynktimer import Timer
import os
import glob
import picamera
import smtplib
import sys, errno
from datetime import datetime
BLYNK_AUTH = 'Ot1KsMauBKoTdiY3CWF3l4OjTlXF3HhI'
# Initialize Blynk
timer = Timer()
#import modules for sending mail
from email.mime.multipart import MIMEMultipart
from email.mime.text import MIMEText
from email.mime.base import MIMEBase
from email import encoders
sender = 'dmmmmm0724@gmail.com'
password = 'xxxxxxxxx'
receiver = 'dm.8718@hotmail.com'
DIR = './Visitors/'
prefix = 'image'
GPIO.setup(26, GPIO.IN, pull_up_down=GPIO.PUD_UP)#Button to GPIO26
#GPIO.setup(26, GPIO.IN) #read output from button sensor
#setup pin
led1 = LED(18)
fan = LED(19)
sensor_type = Adafruit_DHT.DHT11
sensor_pin = 4
servoPIN = 22
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(servoPIN, GPIO.OUT)
GPIO.setup(17, GPIO.IN) #gas
GPIO.setup(21, GPIO.IN) #flame
p = GPIO.PWM(servoPIN, 50) # GPIO 17 for PWM with 50Hz
p.start(5) # Initialization
GPIO.setup(20, GPIO.IN)# rip
#motor setup
stepper_pins=[23,24,25,5]
GPIO.setup(stepper_pins,GPIO.OUT)
stepper_sequence=[]
stepper_sequence.append([GPIO.HIGH, GPIO.LOW, GPIO.LOW, GPIO.LOW])
stepper_sequence.append([GPIO.HIGH, GPIO.HIGH, GPIO.LOW, GPIO.LOW])
stepper_sequence.append([GPIO.LOW, GPIO.HIGH, GPIO.LOW, GPIO.LOW])
stepper_sequence.append([GPIO.LOW, GPIO.HIGH, GPIO.HIGH, GPIO.LOW])
stepper_sequence.append([GPIO.LOW, GPIO.LOW, GPIO.HIGH, GPIO.LOW])
stepper_sequence.append([GPIO.LOW, GPIO.LOW, GPIO.HIGH, GPIO.HIGH])
stepper_sequence.append([GPIO.LOW, GPIO.LOW, GPIO.LOW, GPIO.HIGH])
stepper_sequence.append([GPIO.HIGH, GPIO.LOW, GPIO.LOW, GPIO.HIGH])
#ultrasonic
led = 15
echo = 13
trig = 12
GPIO.setup(echo , GPIO.IN)
GPIO.setup(led , GPIO.OUT)
GPIO.setup(trig, GPIO.OUT)
# Register Virtual Pins of led
@blynk.VIRTUAL_WRITE(1)
def my_write_handler(value):
print('Current V1 value: {}'.format(value[0]))
if int(format(value[0])) == 1:
led1.on()
else:
led1.off()
# Register Virtual Pins of fan
@blynk.VIRTUAL_WRITE(5)
print('Current V5 value: {}'.format(value[0]))
fan.on()
else:
fan.off()
# Register Virtual Pins of gate
@blynk.VIRTUAL_WRITE(6)
p.ChangeDutyCycle(5)
time.sleep(0.5)
p.ChangeDutyCycle(10)
time.sleep(0.5)
print("GATE OPEN")
else:
time.sleep(0.5)
time.sleep(0.5)
print("GATE CLOSE")
# Register Virtual Pins of temperature and humidity
@timer.register(interval=5)
def my_user_task():
humidity, temperature = Adafruit_DHT.read_retry(sensor_type, sensor_pin)
print('Humidity = {:.2f}%\tTemperature = {:.2f}C'.format(humidity, temperature))
blynk.virtual_write(3, '{:.2f}'.format(temperature))
blynk.virtual_write(4, '{:.2f}'.format(humidity))
if temperature >= 30.0:
GPIO.output(19, GPIO.HIGH)
print('Fan on')
blynk.run()
# flame and gas detecton function
@timer.register(interval=1)
def flameGas():
if GPIO.input(17) == 1:
print("gAs detected")
blynk.notify('Gas Leakage')
time.sleep(0.2)
elif GPIO.input(21) == 0:
print("flame detected")
blynk.notify('Fire,go back home now')
time.sleep(0.2)
def send_mail(filename):
msg = MIMEMultipart()
msg['From'] = sender
msg['To'] = receiver
msg['Subject'] = 'Visitor'
body = 'Someone is visit your house'
msg.attach(MIMEText(body, 'plain'))
attachment = open(filename, 'rb')
part = MIMEBase('application', 'octet-stream')
part.set_payload((attachment).read())
encoders.encode_base64(part)
part.add_header('Content-Disposition', 'attachment; filename= %s' % filename)
msg.attach(part)
server = smtplib.SMTP('smtp.gmail.com', 587)
server.starttls()
server.login(sender, password)
text = msg.as_string()
server.sendmail(sender, receiver, text)
server.quit()
print('Sending email')
def capture_img():
print('Capturing')
if not os.path.exists(DIR):
os.makedirs(DIR)
files = sorted(glob.glob(os.path.join(DIR, prefix + '[0-9][0-9][0-9].jpg')))
count = 0
if len(files) > 0:
count = int(files[-1][-7:-4])+1
filename = os.path.join(DIR, prefix + '%0GPIO.setup(26, GPIO.IN, pull_up_down=GPIO.PUD_UP)#Button to GPIO263d.jpg' % count)
with picamera.PiCamera() as camera:
pic = camera.capture(filename)
send_mail(filename)
def send_mailPassby(filename):
msg.attach(part)
server.starttls()
server.quit()
def capture_imgPassby():
print('Capturing')
os.makedirs(DIR)
count = 0
if len(files) > 0:
#@timer.register(interval=1)
def camera():
i = GPIO.input(26)
if i == False:
print ("Someone is visiting your house", i)
capture_img()
# elif GPIO.input(20):
# print('People Passby')
# capture_imgPassby()
def motor():
hha = datetime.now().strftime('%H:%M:%S')
if(hha =='13:56:00'):
while(True):
for row in reversed (stepper_sequence):
for row in stepper_sequence:
GPIO.output(stepper_pins,row)
time.sleep(0.001)
hha2 = datetime.now().strftime('%H:%M:%S')
if (hha2 == '13:56:10'):
print('close')
break
def ultrasonic():
GPIO.output(trig ,True)
time.sleep(0.00001)
GPIO.output(trig ,False)
while GPIO.input(echo)== 0:
srt = time.time()
while GPIO.input(echo) == 1:
end = time.time()
duration = end - srt
distance_cm = duration/0.000058
# print('distance : {}cm' .format(distance_cm))
time.sleep(3)
if distance_cm <= 30:
GPIO.output(led , GPIO.HIGH)
else :
GPIO.output(led , GPIO.LOW)
try:
while True:
blynk.run()
timer.run()
motor()
ultrasonic()
camera()
except KeyboardInterrupt:
sys.exit(0)
GPIO.cleanup()
