HIi
I am using esp 32 and blynk.When I download my code,I cannot using flash button because of provision.Where is my mistake.Can you help me please?
#define BLYNK_TEMPLATE_ID "TMPLebZli4eo"
#define BLYNK_DEVICE_NAME "SmartBox"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
#define USE_WROVER_BOARD
//#define USE_TTGO_T7
#include "BlynkEdgent.h"
BlynkTimer timer1;
#include "DHT.h"
#define DHTPIN 5 //D5 pin of Node MCU
#define DHTTYPE DHT11
int esikdegeri=1500;
int toggleState_1=0;
int toggleState_2=0;
int toggleState_3=0;
int toggleState_4=0;
//int buzzer=18;
int deger=0;
int gazokuma=36;
int lcdColumns = 16;
int lcdRows = 2;
int role_1=27;
int role_2=26;
int role_3=25;
int role_4=33;
int buzzer=18;
int ok=32;
//int sayac=0;
int x=0;
int yukari=35;
int asagi=34;
//Set Degerleri Belirleme
int ayarsayac=1;
int gerilimset=500;
int akimset=500;
int gazsensorset=1000;
int sicaklikset=500;
int nemset=500;
bool acildurum=false;
bool anaekran=false;
bool ayarlar=false;
bool gazsetbelirle=false;
bool ayarsayackontrol=false;
bool gerilimsetbelirle=false;
bool akimsetbelirle=false;
bool sicakliksetbelirle=false;
bool nemsetbelirle=false;
bool gazsetonay=false;
bool akimsetonay=false;
bool nemsetonay=false;
bool gerilimsetonay=false;
bool sicakliksetonay=true;
bool ayarmenu=false;
bool ayarsetmenu=false;
int yukarisayac=0;
int asagisayac=0;
unsigned long acilsimdi=0;
unsigned long acilsonra=0;
unsigned long eskizaman=0;
unsigned long simdikizaman;
unsigned long ayarlarsimdi=0;
unsigned long ayarlareski=0;
unsigned long butonsimdi=0;
unsigned long butoneski=0;
DHT dht(DHTPIN, DHTTYPE);
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
float h , t;
int sayac=1;
#include <PZEM004Tv30.h>
/* Hardware Serial2 is only available on certain boards.
* For example the Arduino MEGA 2560
#if defined(ESP32)
PZEM004Tv30 pzem(Serial2,16,17);
#else
PZEM004Tv30 pzem(Serial2);
#endif
void sendSensor()
float voltage = pzem.voltage();
float current = pzem.current();
float h = dht.readHumidity();
deger=analogRead(gazokuma);
Blynk.virtualWrite(V1, h);
Blynk.virtualWrite(V0, t);
Blynk.virtualWrite(V2, voltage);
Blynk.virtualWrite(V3, current);
Blynk.virtualWrite(V4, deger);
Blynk.virtualWrite(V9,sicaklikset);
Blynk.virtualWrite(V10,gazsensorset);
Blynk.virtualWrite(V11,akimset);
Blynk.virtualWrite(V12,gerilimset);
Blynk.virtualWrite(V13,nemset);
void anadongu()
if(anaekran==true)
anaekran_menu();
Serial.println("Ana EKRAN Cagırıldı...");
//Acil Durumda Cagrılcak Fonksiyon
//if(acilsimdi-acilsonra>100)
//acil_durum();
//acilsimdi=acilsonra;
if(ayarlar==true)
ayarlarmenu();
if(ayarsetmenu==true)
ayarset();
BLYNK_WRITE(V5) {
toggleState_1 = param.asInt();
if(toggleState_1 == 1){
digitalWrite(role_1, LOW);
else {
digitalWrite(role_1, HIGH);
BLYNK_WRITE(V6) {
toggleState_2 = param.asInt();
if(toggleState_2 == 1){
digitalWrite(role_2, LOW);
else {
digitalWrite(role_2, HIGH);
BLYNK_WRITE(V7) {
toggleState_3 = param.asInt();
if(toggleState_3 == 1){
digitalWrite(role_3, LOW);
else {
digitalWrite(role_3, HIGH);
BLYNK_WRITE(V8) {
toggleState_4 = param.asInt();
if(toggleState_4 == 1){
digitalWrite(role_4, LOW);
else {
digitalWrite(role_4, HIGH);
// initialize LCD
lcd.begin();
lcd.backlight();
pinMode(buzzer,OUTPUT);
pinMode(role_1,OUTPUT);
pinMode(role_2,OUTPUT);
pinMode(role_3,OUTPUT);
pinMode(role_4,OUTPUT);
pinMode(ok,INPUT);
pinMode(yukari,INPUT);
pinMode(asagi,INPUT);
Serial.println(F("DHTxx test!"));
dht.begin();
pinMode(gazokuma, INPUT);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Haydar");
lcd.setCursor(0,1);
lcd.print("Gungor");
delay(1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Dogus UNI");
lcd.setCursor(0,1);
lcd.print("Bitirme Projesi");
delay(1500);
lcd.clear();
BlynkEdgent.begin();
timer1.setInterval(2000L,sendSensor);
timer1.setInterval(1500L,anadongu);
timer1.setInterval(200L,butonkontrol);
BlynkEdgent.run();
timer1.run();
//timer.run();
void dht11_olcum()
lcd.clear();
// float f = dht.readTemperature(true);
// if (isnan(h) || isnan(t) || isnan(f))
// Serial.println(F("Failed to read from DHT sensor!"));
// return;
//lcd.clear();
lcd.setCursor(0,0);
lcd.print("Sicaklik:");
lcd.setCursor(11,0);
lcd.print(t);
lcd.setCursor(0,1);
lcd.print("Nem:");
lcd.setCursor(11,1);
lcd.print(h);
void gaz_olcum()
lcd.clear();
//Serial.println("Deger :");
//Serial.println(deger);
lcd.setCursor(0,0);
lcd.print("Gaz Deger:");
lcd.setCursor(10,1);
lcd.print(deger);
void elektrikselolcum()
lcd.clear();
if(voltage != NAN)
Serial.print("Voltage:");
Serial.print(voltage);
Serial.println("V");
//Serial.println(“Error reading voltage”);
if(current != NAN)
Serial.print("Current: ");
Serial.print(current);
Serial.println("A");
Serial.println("Error reading current");
float power = pzem.power();
if(current != NAN)
Serial.print("Power: ");
Serial.print(power);
Serial.println("W");
Serial.println("Error reading power");
float energy = pzem.energy();
if(current != NAN)
Serial.print("Energy: ");
Serial.print(energy,3);
Serial.println("kWh");
Serial.println("Error reading energy");
float frequency = pzem.frequency();
if(current != NAN)
Serial.print("Frequency: ");
Serial.print(frequency, 1);
Serial.println("Hz");
} else
Serial.println("Error reading frequency");
float pf = pzem.pf();
if(current != NAN)
Serial.print("PF: ");
Serial.println(pf);
Serial.println("Error reading power factor");
lcd.setCursor(0,0);
lcd.print("Voltage:");
//Gerilim
lcd.print(voltage);
lcd.setCursor(0,1);
lcd.print("Current:");
//Akım
lcd.print(current);
//delay(3000);
//lcd.clear();
//lcd.setCursor(0,0);
//lcd.print("Power:");
//Güç
//lcd.setCursor(11,0);
//lcd.print(power);
//lcd.setCursor(0,1);
//lcd.print("Frequency :");
////Frekans
//lcd.setCursor(11,1);
//lcd.print(frequency);
// float v = pzem.voltage();
// if (v < 0.0) v = 0.0;
// Serial.println(v);Serial.println("V; ");
// float i = pzem.current();
// if(i >= 0.0){ Serial.println(i);Serial.println("A; "); }
// float p = pzem.power();
// if(p >= 0.0){ Serial.println(p);Serial.println("W; "); }
// float e = pzem.energy();
// if(e >= 0.0){ Serial.println(e);Serial.println("Wh; "); }
void acil_durum()
if(deger>gazsensorset)
Blynk.logEvent("gaz_tehlkes","Gaz Tehlikesi var.");
lcd.clear();
acildurum=true;
anaekran=false;
ayarlar=false;
lcd.setCursor(0,0);
lcd.print("Acil Durum!!!");
lcd.setCursor(0,1);
lcd.print("Gaz Tehlikesi");
digitalWrite(buzzer,HIGH);
digitalWrite(role_1,LOW);
digitalWrite(role_2,LOW);
digitalWrite(role_3,LOW);
digitalWrite(role_4,LOW);
else if(voltage>gerilimset)
Blynk.logEvent("gerilim_tehlikesi","Gerilim Tehlikesi...");
lcd.clear();
acildurum=true;
anaekran=false;
ayarlar=false;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Gerilim Tehlikesi");
else if(current>akimset)
Blynk.logEvent("yksek_akim_","YÜKSEK AKIM UYARISI");
lcd.clear();
acildurum=true;
anaekran=false;
ayarlar=false;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Akim Tehlikesi");
else if(t>sicaklikset)
Blynk.logEvent("yksek_scaklk","YÜKSEK SICAKLIK...");
lcd.clear();
acildurum=true;
anaekran=false;
ayarlar=false;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Sicaklik Tehlikesi");
else if(h>nemset)
Blynk.logEvent("krtk_nem_uyarisi","KRİTİK NEM UYARISI");
lcd.clear();
acildurum=true;
anaekran=false;
ayarlar=false;
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("Nem Tehlikesi");
acildurum=false;
digitalWrite(buzzer,LOW);
void ayarlarmenu()
if(ayarsayac==1)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Gaz Sensor");
lcd.setCursor(0,1);
lcd.print("Set Belirleme");
if(ayarsayac==2)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Gerilim");
lcd.setCursor(0,1);
if(ayarsayac==3)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Akim");
lcd.setCursor(0,1);
if(ayarsayac==4)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Sicaklik");
lcd.setCursor(0,1);
if(ayarsayac==5)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Nem");
lcd.setCursor(0,1);
void ayarset()
if(gazsetbelirle==true)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Gaz Set");
lcd.setCursor(0,1);
lcd.print(gazsensorset);
if(gerilimsetbelirle==true)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Gerilim Set");
lcd.setCursor(0,1);
lcd.print(gerilimset);
if(akimsetbelirle==true)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Akim Set");
lcd.setCursor(0,1);
lcd.print(akimset);
if(sicakliksetbelirle==true)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Sicaklik Set");
lcd.setCursor(0,1);
lcd.print(sicaklikset);
if(nemsetbelirle==true)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Nem Set");
lcd.setCursor(0,1);
lcd.print(nemset);
void anaekran_menu()
if(sayac==1)
dht11_olcum();
//Serial.println("Fonksiyon Çalıştı");
if(sayac==2)
gaz_olcum();
if(sayac==3)
elektrikselolcum();
sayac++;
if(sayac==4)
sayac=1;
//lcd.clear();
void butonkontrol()
if(digitalRead(ok)==1)
x++;
if(x>4)
x=0;
if(x==0)
ayarlar=false;
ayarsetmenu=false;
anaekran=true;
if(x==1)
anaekran=false;
ayarlar=true;
ayarsetmenu=false;
if(x==2)
anaekran=false;
ayarsetmenu=true;
ayarlar=false;
if(ayarsayac==1)
gazsetbelirle=true;
if(ayarsayac==2)
gerilimsetbelirle=true;
if(ayarsayac==3)
akimsetbelirle=true;
if(ayarsayac==4)
sicakliksetbelirle=true;
if(ayarsayac==5)
nemsetbelirle=true;
if(x==3)
//setonay=true;
//////////Ayar Kontrol
if(ayarlar==true)
if(digitalRead(yukari)==1)
ayarsayac++;
if(digitalRead(asagi)==1)
ayarsayac--;
if(ayarsayac>5)
ayarsayac=5;
if(ayarsayac<1)
ayarsayac=1;
gazsensorset++;
gazsensorset--;
//////Gerilim
if(gerilimsetbelirle=true)
gerilimset++;
gerilimset--;
//////Akim
akimset++;
akimset--;
//Sicaklik
sicaklikset++;
sicaklikset--;
/////Nem
nemset++;
nemset--;
//////////AyarKontrol bitiş
