I am thinking of buying a new hardware. Can anyone help me choose?
I have these choices in mind -
Raspberry Pi 3
Linkit one
Particle Photon
Intel Edison
I live in India and will most probably ship them from Either Adafruit or Sparkfun.
Raspberry Pi 3
Linkit one
Particle Photon
Intel Edison
Do you have some ideas to implement? Or you want just to try something new? What about Wemos D1? I like it price and Wi-Fi onboard.
I want to board which is easy to code, has wifi onboard and can easily connect to blynk. I want to make IOT applications. @Dmitriy
Of course SparkFun Blynk Board! What else?!
Next choice would be Particle Photon, because I like pretty reliable OTA.
I love particle photon. They are easy to set up and I like being able to access and upload code and projects from any computer with an Internet connection using particles web Ide. I love their documentation as well. I also like the transition from wifi to cellular with the same footprint and layout I can actually just unplug a photon and plug in an electron and run the same program with cellular in a remote location. Can’t speak for the other platforms because I haven’t used them. I got stuck on particle Oh and I have blynk running on all of them
WeMos D1 Mini for me at less than $4.
Sounds Awesome. Can you give me links for sites from where I can order them?
Couldn’t find it on adafruit and sparkfun
I don’t know a lot about it. There are different versions of it I believe, but never used it.
I just find the ease of use on the photon superb. The in app set up is simple
you don’t code a board, you code code!
I think you missed the point. No problem
Yes, for me, missing the point is no problem…
@KAUSTUBHAGARWAL the website for the WeMos (full size and Mini) is at http://www.wemos.cc/ with the forum at http://forum.wemos.cc/
The WeMos AliExpress store is at http://www.aliexpress.com/store/1331105
A version 2 was released about 2 months ago for the D1 Mini and I would recommend buying direct from the WeMos store on AliExpress as there are lots of copies around and some are version 1.
