When i reboot the wifi router the LED also turned OFF ,blynk nor keep the LED light ON ,
When i reboot the wifi router the LED also turned OFF ,blynk not keep the LED light ON .
what i want is when the WIFI is rebooted the device is still on reconnect again …
im using NODE MCC ESP8266 12 E
http://docs.blynk.cc/#blynk-main-operations-state-syncing
Here is my code please add Sync function for me thanks
#include <SimpleTimer.h>  // Essential for all Blynk Projects
char auth[] = "6bca700d060343298fb2a29e0f9f1b6e";
char ssid[] = "100/GB";
char pass[] = "PakistaN123$";
bool Connected2Blynk = false;
  timer.setInterval(11000L, CheckConnection ); // check if still connected every 11 seconds
  Serial.println("\nStarted");
  MyWiFi();
void MyWiFi(){
  int mytimeout = millis() / 1000;
  WiFi.begin(ssid, pass);
    delay(500);
    Serial.print(".");
    if((millis() / 1000) > mytimeout + 3){ // try for less than 4 seconds to connect to WiFi router
      break;
  if(WiFi.status() == WL_CONNECTED){
    Serial.print("\nIP address: ");
  else{
    Serial.println("\nCheck Router ");
  Blynk.config(auth);
  Connected2Blynk = Blynk.connect(1000);  // 1000 is a timeout of 3333 milliseconds
  while (Blynk.connect(1000) == false) {
      break;
void CheckConnection(){
  Connected2Blynk = Blynk.connected();
  if(!Connected2Blynk){
    Serial.println("Not connected to Blynk server");
    MyWiFi();
  else{
    Serial.println("Still connected to Blynk server");
  if(Connected2Blynk){
    Blynk.run();  // only process Blyk.run() function if we are connected to Blynk server
still got the same same problem after syncing .im using LED on digital pin GP13 …
