When I get notification from PIR sensor or smoke sensor, my arduino disconnects from the wifi and I lose the ability of using Blynk until it reconnects two minutes later
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to use Adafruit CC3000 breakout
  to connect your project to Blynk.
  For this example you need Adafruit_CC3000_Library library:
    https://github.com/adafruit/Adafruit_CC3000_Library
  Note: Firmware version 1.14 or later is preferred.
  1. Update pin definitions according to your setup.
  2. Change WiFi ssid, pass, and Blynk auth token
  3. Run :)
// These are the interrupt and control pins for СС3000
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
#include <Adafruit_CC3000.h>
#include <BlynkSimpleCC3000.h>
#include <Servo.h>
char auth[] = "7ea06fe13bc04031b22948c5164cb4d9";
// Choose wifi_sec from WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
char ssid[] = "MOP";
char pass[] = "1234567890";
int wifi_sec = WLAN_SEC_WPA2;
int inputmotion=29;
//int inputsmoke=34;
int moisturepin = A14;
int tempPin = A11;
int percentValue =0;
BLYNK_READ(V5) //Blynk app has something on V5
  int tempval = analogRead(tempPin);
  float temp = tempval * 0.48828125;
  Blynk.virtualWrite(V5, temp); //sending to Blynk
BLYNK_READ(V6) //Blynk app has something on V6
  int moisval = analogRead(moisturepin);
  percentValue = map(moisval, 1023, 465, 0, 100);
  if(percentValue>100)
    percentValue = 100;
  Blynk.virtualWrite(V6, percentValue); //sending to Blynk
Servo servo;
BLYNK_WRITE(V3)
  servo.write(param.asInt());
  Blynk.begin(auth, ssid, pass, wifi_sec);
  servo.attach(40);
  pinMode(inputmotion, INPUT);
//  pinMode(inputsmoke, INPUT);
  int motionval = digitalRead(inputmotion);  // read input value
//  int smokeval = digitalRead(inputsmoke);
  //float moistureval = analogRead(inputmoisture);
  if (motionval == HIGH) {
  Blynk.notify("motion detected");
  delay(1);
//  if (smokeval == HIGH) {
 // Blynk.notify("smoke detected");
  delay(1);
  1. Format your code to make it readable
  2. Use timers. Void Loop should ideally contain only Blynk.run - this is the reason of your disconnects
  3. Also learn how to change states and don’t send “million” of notifications every second. Only send when state changes.
  4. Combining timers + states is what you need
I tried to use timers, but I couldn’t and I tried to use void loop before the set up loop but the notifications didn’t work.
Can you please fix the code(only the part of notification) and send it back
I fix code for bitcoins only :slight_smile:
I recommend you start with going through examples that are included in the Blynk library and here:
https://examples.blynk.cc
This is a great way of learning Blynk basics and main concepts. Actually, everything you ask for is covered by Blynk examples.
…and accept only integer numbers
