[quote=“Pavel, post:21, topic:1212, full:true”]
Y scale in graph is under your control already
[/quote]I can change the range by program from the device? Do you have an example?
Check this thread please:
I would like to see an automatic translate function in the community forums!
Allow multiple gauges/ LEDs/ indicators - anything with a read-only function - to display values from the same pin. Why? sometimes it’s useful to have an instantaneous read-out of the value of a sensor as well as a graph view. E.g. I have a blynk that displays a graph over the values reported by an IR sensor. I’d like to know the exact value of said sensor at any given moment.
Allow the Android app to prevent the screen from sleeping when a Blynk is running.
You’ll be amazed by upcoming Logger Widget
- GPS widget with possibility to send NMEA protocol values to arduino
- Direct connection between blynk app and esp8266 running server without internet access
- A way to “snapshot” graphs/value displays at particular time for future references
- Setting Threshold values in graph
Sorry if I sound like a broken record with the above requests.
I would like to see the ability to control multiple different microcontrollers with one Blynk “remote”, like have buttons for 2 different ESP8266’s and other controls for an Arduino all on the same page.
And either a way to export “remotes” to standalone apps, or an interface like Unified Remote, personally I would prefer the style of Unified Remote so you do not need to exit one app to get to a different control set in a different app. Additionally if the Unified remote style is pursued the quick action bar that is used there is very fast for changing panels…
And most of all I would love to see Tasker integration.
Stability on the standalone ESP8266 platform.
For those of us using the Raspberry Pi it would be great to be able to embed a live webcam stream, even if it would only be able to run on own server(not neccessarily Blynk). That way I could have more feedback from my project. Another use would be a security cam for your house. The app NetIO, for example, allows its users to embed a small webpage containing a stream. Anyways, thanks for this awesome app!
Love the cam idea! we will definitely do that.
I would like a lot more space (smaller buttons etc?) to place buttons, sliders, widgets etc.
On my ipad the buttons are very big and could be a lot smaller.
Also i would like to see multiple dashboard per project, so that one could have one sketch/auth-code for multiple purposes.
Keep up the good work guys, love your app!
open source android app for switching on lights at least
Hi @fii, we are contributing a lot to open source community. But if we give everything - we will need to stop making Blynk. However, you’ll be able to share almost a standalone “app”
Look at the lates Sharing feature - this is the first step towards it
Multi tab option will increase display area and user will be able to divide widgets in categories such as Read Sensors tab, Control Tab, Settings Tab etc.
multiple tabs or even better multiple running projects
/edit: i know i posted this somewhere else as well, excuse the double post
ios as well?
iOS after 2 weeks review =) as usually. but for iOS also. Yes.
spasiba
thank you
vilen dank
