What variable is the IP ?
int
char
unit8_t …
Isn’t that just an unsigned 8bit integer? After all, it’s just a couple small numbers.
I see you are doing something with SmartDoors, a bit off topic, but can you tell me what you want to do? I have plans for smart doors too, but I’m not sure how to set it all up.
After I send this number for Serial.begin
while(Serial.peek()==‘I’+‘P’+‘1’){
Serial.read();
unit8_t ipp1=Serial.parseInt();
I’m not sure what you mean by this. Do you have a problem? Is there something not working?
the code compiles but does not work
int first_octet =190;
int second_octet = 168;
int third_octet = 0;
int fourth_octet = 17;
This works!!!
It’s something of caveat, if you do like this:
Blynk.begin(auth, wifi, "Wanda2.4", "blehblehbleh", "192.168.0.10", 8442);
It will work too.
