What this wrong?
#include <Servo.h> // include Servo library
Servo horizontal; // horizontal servo
int servoh = 90;     // stand horizontal servo
Servo vertical;   // vertical servo
int servov = 90;     // stand vertical servo
// LDR pin connections
//  name  = analogpin;
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
// servo connections
// name.attacht(pin);
  horizontal.attach(9);
  vertical.attach(10);
  int lt = analogRead(ldrlt); // top left
  int rt = analogRead(ldrrt); // top right
  int ld = analogRead(ldrld); // down left
  int rd = analogRead(ldrrd); // down rigt
  int dtime = analogRead(4)/20; // read potentiometers
  int tol = analogRead(5)/4;
  int avt = (lt + rt) / 2; // average value top
  int avd = (ld + rd) / 2; // average value down
  int avl = (lt + ld) / 2; // average value left
  int avr = (rt + rd) / 2; // average value right
  int dvert = avt - avd; // check the diffirence of up and down
  int dhoriz = avl - avr;// check the diffirence og left and rigt
  if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
  if (avt > avd)
    servov = ++servov;
     if (servov > 180)
      servov = 180;
  else if (avt < avd)
    servov= --servov;
    if (servov < 0)
    servov = 0;
  vertical.write(servov);
  if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
  if (avl > avr)
    servoh = --servoh;
    if (servoh < 0)
    servoh = 0;
  else if (avl < avr)
    servoh = ++servoh;
     if (servoh > 180)
     servoh = 180;
  else if (avl = avr)
    // nothing
  horizontal.write(servoh);
   delay(dtime);
hai friend all
can help me
this code what wrong?
not working?
can help me friend
but want to connect to blynk
this link http://www.instructables.com/id/Arduino-Solar-Tracker/?ALLSTEPS
You’ll get a better response if you describe what you are trying to achieve, and how it is not working, as well as basic information about the device you’re using, etc.
That said, if your issue is a failure to connect to the Blynk server, you’ll need the relevant calls to Blynk in your code.
// At the top of your sketch, include the relevant blynk headers, e.g. for Yun, something like
// #include <Bridge.h>
// #include <YunClient.h>
// #include <YunServer.h>
// #include <BlynkSimpleYun.h>
char *auth = "your.auth.token.here";    // You get this token from the Blynk app itself.
void setup(void) {
    Blynk.begin(auth);
void loop(void) {
That should be enough to get you started down the right path. If you still experience failure, describe precisely what you are trying to do, and what is not working, and maybe you’ll receive more assistance.
thank’s your answer ^^
