What is the String format for Time Input datastream?
Hi.
I’m setting the datastreams for my template, And I would like to set up a default value for the datastream of a Time Input widget (Star/Stop).
Anybody knows what is the String format for this widget?
It’s an array of data, as described here:
You should leave the default value blank.
If you want your sketch to use default start/stop times then you should set these in the sketch.
Thanks Pete, a straight answer!
