What is the difference between "blynk.virtualWrite(1, val)" & "vPin1.write(val)"?
A smart garden with that I’m building with Node.js writes to some virtual pins every 5 mins. Im having a hard time understanding the difference between the following snippets of code:
EDIT: Would this post be better categorized as “Hardware and Blynk Libraries”?
var vPin1 = new blynk.VirtualPin(1);
vPin1.write(val)
VS:
I believe the main purpose in this use of variables is to make your code a bit easier to read, based on your choice of variable name such as var doorLock = or var roomLight = (or var vPin1 = which is too generic :stuck_out_tongue: ) , vs trying to remember what the (1) AKA vPin1 is used for in blynk.virtualWrite(1, val)
ok so aside from that, blynk.virtualWrite(pin, val) will behave the same?
