What example to use
What example of Arduino should I use to connect an Arduino one with the esp8266 module and an esp01 adapter to use with blynk.
What’s an “Arduino one with the esp8266 module”?
101? Or Arduino Uno?
Edit:
Uno = https://examples.blynk.cc/?board=Arduino%20Uno&shield=ESP8266%20WiFi%20Shield&example=GettingStarted%2FBlynkBlink
Sorry if I have not explained myself well, it is an arduino one and I wanted to connect it to the blynk application with a wifi module, I already found the solution in this youtube video, you have to modify some parameters of the example ide.
It is for the arduino one, you have to modify some parameters of the sketch as seen in this youtube video that I found later, thanks for your help.
Arduino Uno + ESP-01
