What code to BLYNK on DS18B20 on one wire ?
the Dallas Temperature “TwoPin_DS18B20” example works fine…
// Basic reading of sensors on a network
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
//Chip = DS18B20
// order of discovery
//Roof ROM = 28 CC C2 E9 3 0 0 63
//Kitchen ROM = 28 61 EB E9 3 0 0 7E
//highTemp ROM = 28 B3 F2 D8 5 0 0 4D
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
* 30/12/2015 Blynk version v0.3.1
* Temp Sensor Terminations: 5V, GND, Data
* Source Cable type Terminations
* Freetronics Cat5e 5V Wh/Bl, GND Bn, Data Bl
* Core electronics High Temp 5V Wh/Or, GND Wh, Data Wh/Bl Mil-Spec Wire
* China Water Resist 5V , GND , Data --> Rd, Bk, Yl TBD
* NOTE: Starting or Stoping the Serial monitor on the PC will reset the Arduino.
#include <OneWire.h>
#include <Ethernet.h>
OneWire ds(2); // on pin 10 (a 4.7K resistor is necessary)
char auth[] = "auth"; // 30/12/2015
float celsius;
void setup(void) {
delay( 100 ); // allow some time (50 ms) after powerup and sketch start,
// for the Etherten Wiznet W5100 Reset IC to release and come out of reset.
Blynk.begin(auth); // auto ethernet setup, DHCP, defaults: Name: WIZnetFEFEED MAC: DE:ED:BA:FE:FE:ED
// Wait until connected true
// Setup timer functions to be called every x milli seconds. Widgets set to PUSH
timer.setInterval(1000L, sendUptime); // V5 widget
timer.setInterval(5000L, sendV0Temp); // History graph
timer.setInterval(5000L, sendV1Temp); // History graph
timer.setInterval(5000L, sendV2Temp); // History graph
timer.setInterval(5000L, sendV3Temp); // History graph
Serial.println("Sketch: BlynkTempLogger0");
} // setup
void sendV0Temp() // V0 function. Set widget to PUSH
Blynk.virtualWrite(V0, celsius);
void sendV1Temp() // V0 function. Set widget to PUSH
int i = 0;
Blynk.virtualWrite(V1, i);
void sendV2Temp() // V2 function. Set widget to PUSH
int i = 0;
Blynk.virtualWrite(V2, i);
void sendV3Temp() // V3 function. Set widget to PUSH
int i = 0;
Blynk.virtualWrite(V3, i);
/*0
BLYNK_READ(V4) // Blynk functions only operate when the phone app is active.
{ // History graph is not updated live. change time base to update running app screen.
//int i = 100;
Blynk.virtualWrite(V4, celsius); // send value to V0 widget
void sendUptime() // V5 function. set widget to PUSH
void loop(void) // Main loop
byte i;
byte present = 0; // initialize device present variable
byte type_s; // device type
byte data[12]; // data array
byte addr[8]; // address array
//float celsius;
if ( !ds.search(addr)) { // search finds device 8 Byte ROM address
Serial.println("No more addresses."); // no new addresses
Serial.println();
ds.reset_search(); // clear state. for next start search from begining
delay(250); // bus held low period
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX); // print 8 element array ROM address
// CRC check Byte 7
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
break;
case 0x28: // my devices
Serial.println(" Chip = DS18B20"); // my devices
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset(); // one wire reset, device asserts a presence pulse
ds.select(addr); // get device address
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(500); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset(); // one wire reset, device asserts a presence pulse
ds.select(addr); // get device ROM address
ds.write(0xBE); // Read Scratchpad of device
Serial.print(" Data = ");
Serial.print(present, HEX); // first "1" in print to line
Serial.print(" "); // whitespace
for ( i = 0; i < 9; i++) { // we need 9 bytes of data that represents the temperature
data[i] = ds.read();
Serial.print(data[i], HEX); // print each byte to serial
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX); //
Serial.println();
// End of setup ??
// Start reading ??
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) { // mine is 0
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
//fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.println(" Deg C");
Serial.println(" ");
} // loop
Where to enter the address of the sensor, and how to do so was esp8266 (WEMOS D1 R2)
Do you have just one sensor or more? If you have only one, entering the address is not required.
I have more sensors.
How to do to degrees Celsius ?
You can just replace the F
with C
… should be
sensors.getTempC(tempSensor1);
Thank you.
Everything works well.
Woo hoo! Good to hear!
And did you ever at Eventor BLYNK. E.g. V1 If the temperature is higher than 25 degrees Celsius it gives a signal to pin 2 (D2 - wemos d1) (eg relay with buzzer)
No I haven’t played with any of the eventor stuff yet.
