What are the widget properties supported as of now
As per example and docs it says only lable and color only two properties are supported currently. Are there any more properties available right now and planned for near future. For example. rendered or visible property so I can set perticular button dynamically on app based on certain condition.
For example, from menu user can select how many button he wants and based on number selected on menu, only that many buttons go visible in app and other buttons are not visible.
Thanks,
Krunal
Hello. All properties documented here - http://docs.blynk.cc/#blynk-main-operations-change-widget-properties. There are not only color/label. Please read carefully.
If you think some property would be very helpful for your project - just create separate topic for it with explanation how would you use it. There is high chance we will add it.
Thanks Dmitriy, I will create new topic for new property.
Thanks,
Krunal
