Wemos d2 mini close connection to the internet
Hi , I try to make am termometre wireless, connecting Wemos with my acces point wireless with blink an I use blynk application to display temperature form my room when I go in town or at school but I don’t know why if I connect the power to Wemos that connect to the internet and give in my phone the tempereature but in 20 30 seconds that’s disconnect ;
in blynk application show me where is connected and in 20 second show that device is disconnected
I forgot to say that Wemos I connect to my acces point
and phone not that use 3G internet
#include <OneWire.h>
#include <ArduinoOTA.h>       // for local OTA updates
// Data wire is plugged into pin D4 on the Arduino
#define ONE_WIRE_BUS D4
char auth[] = "c45b270cbf274be1885dc5d23f6436a6";
char ssid[] = "528";
char pass[] ="tuborgbeer";
void setup(void)
 Blynk.begin(auth, ssid,pass);
  sensors.begin();
void loop(void)
  sensors.requestTemperatures(); // Send the command to get temperatures
if (Blynk.connected()) {   // to ensure that Blynk.run() function is only called if we are still connected to the server
    Blynk.virtualWrite(0,sensors.getTempCByIndex(0));
here is the code
@Arsed that is nothing like a Blynk sketch.
You haven’t got Blynk.run() in your loop().
You can’t use delay() with Blynk and you must use SimpleTimer.
Study the PushData example.
