Wemos d1r1 with blynk
Hello everybody
i am trying to connect to blynk via Wemos D1R1
followed the procedure
inserted file locations in the terminal /documents/arduino/libraries/blynk/blynk-ser.sh
installed brew socat inserted the script folder location and it seem to be on the right path
it says that its connecting and transferring data but stuck in the same status without connecting what could be the problem? the terminal message i displays ; Connecting: GOPEN:/dev/tty.wchusbserialfd120,raw,echo=0,clocal=1,cs8,nonblock=1,ixoff=0,ixon=0,ispeed=9600,ospeed=9600,crtscts=0 <-> openssl-connect:blynk-cloud.com:443,cafile=/Users/katsiv/Documents/Arduino/libraries/libraries/Blynk/scripts/certs/server.crt,nodelay
2020/04/01 22:40:54 socat[4134] N opening character device “/dev/tty.wchusbserialfd120” for reading and writing
2020/04/01 22:40:54 socat[4134] N opening connection to LEN=16 AF=2 45.55.96.146:443
2020/04/01 22:40:54 socat[4134] N successfully connected from local address LEN=16 AF=2 192.168.1.4:50062
2020/04/01 22:40:54 socat[4134] N trusting certificate, commonName matches
2020/04/01 22:40:54 socat[4134] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2020/04/01 22:40:54 socat[4134] N SSL connection compression “none”
2020/04/01 22:40:54 socat[4134] N SSL connection expansion “none”
2020/04/01 22:40:54 socat[4134] N starting data transfer loop with FDs [5,5] and [8,8]
it tries to reconnect every 15 minutes or so
Thanks!
Why would you use a device that has built-in WiFi to connect via the USB script running on a PC?
