This says somthing in your code or network prevented timely device-server communication, thus the disconnection.
This (2.9 second ping) indicates that you may have some network or interference issue that happens once in awhile.
Well done !!
The problem is that it happens constantly with the Wemos and never with the esp-01. But thatâs not a problem anymore.
Pete convinced me to switch to MQTT. I donât know if I will be using Blynk anymore, not because itâs a bad platform but primarily because as they already said they wonât develop the âBlynk 1.0â anymore and apparently (if I understood correctly) you have to pay if you want more features/more devices and local server doesnât seem to be a thing anymore.
Secondly we only have Apple devices and the Home app with HomeKit and Node-Red seem to work very well and the fact that you can control all the things using Siri via Apple Watch and HomePod makes it the best way for me.
Also since my âHubâ will serve as the whole house heating system thermostat I canât wait until the ânew Blynkâ comes out as a stable version because winter is coming.
Thanks again to all of you and ask me everything you want to know about my setup and devices.
I am sure blynk has no discriminatory feelings against Wemos or ESP-01 (unlike some users
)⌠more likely that they are slightly differing tech and thus respond differently to your network environment, and is only more notable with Blynk due itâs need for constant communication link.
Quite simply⌠we donât really know what will or will not be a thing, supported, changed, etc⌠nor when⌠until it happens (if it happens
The end of oil is closer than you think
