Wemos D1 mini disconnected
I am using the ESP8266 Standalone sketch. When I run the simple program as soon as I touch the button I programmed it says “Your WeMos D1 was disconnected”
Every time, why??
Provably hug in your code, that causes wemos to crash and reboot…
If you can post/share your code that would be helpful.
Just the standard code right from the example. I had to delete the leading < so it would display right for the include statements.
#define BLYNK_PRINT Serial // Comment this out to disable prints and save space#include ESP8266WiFi.h>
`#include BlynkSimpleEsp8266.h>
char auth[] = “XXXXXXXXXXXXXXXXXXX”;
Blynk.begin(auth, “xxxxxx”, “xxxxxx”);
I had the WEMOS D1 selected and not the mini. Go figure.
