Webhook widget with header
I found a nice way to interact with Home Assistant from Blynk via a Webhook.
But I need some help to configure the Webhook Widget.
I need to send this (curl example):
curl -X POST -H “x-ha-access: xxxx”
-H “Content-Type: application/json”
-d ‘{“state”: “/pin/”, “attributes”: {“unit_of_measurement”: “°C”, “friendly_name”: “Temp”}}’
https://xxx.com:8123/api/states/sensor.temp
Is it possible to configure the header ““x-ha-access: xxxx”” in the webhook widget?
How?
Cheers
Tomas
Hello. Sorry. Right now this is not supported.
