Webhook getting bad results
when I run just the basic webhook activated by button sending to V20 the data is as follows. The one and zero is the button being pressed sending 1 then 0. I had it working when using ESP8266. what am I missing?
#define BLYNK_MAX_READBYTES 512
#include <Ethernet.h>
char auth[] = "*************************************";
BLYNK_WRITE(V20)
  Serial.println("WebHook data:");
  Serial.println(param.asStr());
  Blynk.begin(auth);
NOTE : Blynk cloud has limitation for webhook widget - you are allowed to send only 1 request per second. You can change this on local server with webhooks.frequency.user.quota.limit. Please be very careful using webhooks, as many resources not capable to handle even 1 req/sec, so you may be banned on some of them. For example thingspeak allows to send 1 request per 15 seconds.
I am only sending the request once using Blynk example.
The first response is the button being pressed. (Webhook data: 1)
The second is the correct results. (Webhook data: Results)
The third is the button being released. (Webhook data: 0)
This is what the webhook is sending:
http://api.sunrise-sunset.org/json?lat=38.8935979&lng=-95.2765293&sunset=1&date=today&formatted=0
So what exactly doesn’t work than?
As you can see from the picture I get 3 results. I need to parse the results.
I should only get the results from the webhook get and not the button pressed and released value.
You have few options :
  1. check if this is 1 or 0 and skip.
  2. Move webhook trigger to another pin.
Poor way to solve Blynk Webhook software issue.
Also you I can not get the url to work when sent from hardware, only works when entered into webhook widget directly.
Blynk.virtualWrite(V0, "https://api.sunrise-sunset.org/json?lat=50.4495484&lng=30.5253873&date=2016-10-01");
The problem in the way you use webhook and not in webhook at all. Please read related documentation. It has all answers you need.
Dear Dmitriy;
i used webhook to send my sensor data to thingspeak also but it send the data 4 times and then server get offline.
Why?
i also send data one time in 30 seconds.
What server?
My cc3000 shield micro web-server disconnected from blynk after sending data 3 or 4 times
If this client code it not web-server but web client.
Dear,
I send sensors data on virtual pin and used webhook to send this data to thingspeak also, when it send data to thingspeak 3 or 4 times it get disconnected from blynk.
i also used 4 buttons to control 4 appliances but when i turn on all of 4 buttons then it did not get off.
// These are the interrupt and control pins for СС3000
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
#include <Adafruit_CC3000.h>
#include <BlynkSimpleCC3000.h>
#include <string.h>
#include<stdlib.h>
#include “utility/debug.h”
#include “DHT.h”
#include <avr/wdt.h>
// temperature and humidity sensor
#define DHTPIN 7
#define DHTTYPE DHT22
int gas_status;
char auth[] = “ee25eeb01b334bb695c01da8c27a675d”;
// Choose wifi_sec from WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
char ssid[] = “Shahbaz”;
char pass[] = “pakistan123”;
int wifi_sec = WLAN_SEC_WPA2;
// Define variable and pins for sensors
const int sensorPin[] = {22, 24, 26, 28, 30 };
int Gassensor = 6;
// For temperature and humidity
DHT dht(DHTPIN, DHTTYPE);
for (byte idx = 0; idx < 5; idx++) {
pinMode(sensorPin[idx], INPUT);
//Configured this pin 6 as input for Gas sensor
pinMode(Gassensor, INPUT);
Blynk.begin(auth, ssid, pass, wifi_sec);
// Setup a function to be called every 30 second
timer.setInterval(30000L, myTimerEvent);
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void myTimerEvent()
// Please don’t send more that 10 values per second.
// Get data from DHT 22 & transform to integers
float h = dht.readHumidity();
//Get data from gas sensor
int g = digitalRead(Gassensor);
if(g==0)
gas_status = 1;
gas_status = 0;
//Get data from flame sensor
bool anySensor = false;
if (digitalRead(sensorPin[idx])) {
anySensor = true;
int fireState=anySensor;
// print data collected by sensors on serial monitor
Serial.print("Temperature = ");
Serial.println(t);
Serial.print("Humidity = ");
Serial.println(h);
Serial.print("Gas Status = ");
Serial.println(gas_status);
Serial.print("FlameStatus = ");
Serial.println(fireState);
int temperature = (int) t;
int humidity = (int) h;
String tem=String(temperature, DEC); //Thingspeak only data stream is string type
String hum=String(humidity, DEC); // Converting integer data to string
String gas=String(gas_status, DEC);
String flame=String(fireState, DEC);
Blynk.virtualWrite(V0, tem, hum, flame, gas);
please check the sketch above.
Please properly format sketch above. Otherwise it is difficult to read.
