You say that my test code works OK.
Does it actually update your Google spreadsheet from the settings you have in pushingbox?
Yep, running your test code with my URL displays the values in the Google sheet perfectly well.
I can’t understand why it doesn’t work in the sketch that you sent me via PM.
I did notice I an earlier post that you had a % in the url that you don’t need.
Are you 100% sure you have all the webhook details correct?
Maybe your problem is all that servo stuff and the delays. Try putting the virtualWrite() just inside the if statement rather than at the end and consider commenting out the servo and blynk.run() for testing purposes.
The webhook url is the same as in your example sketch, so there’s no problem with that. I’ll try what you suggested, but wasn’t Blynk.run() needed to make it send the data?
No Blynk.run() is only needed to stop your system crashing during super slow functions like moving servos etc.
@Costas Simply moving the Blynk.virtualWrite()
to before the servo and RFID delays seemed to completely fix the problem. Thanks for all your help
