Hi blynkers,
I’m just playing with the Webhook widget and I’m struggling when I try to use it from Local or Cloud Server to Local Server project.
I’m able to send data using Webhook between projects like this for Cloud Server: http://blynk-cloud.com/-----------token-here-------/update/v2?value=/pin/
This way V2 value is updated properly.
Depending on how you’ve set up your local network, router etc, the request might not reach your local server. Using DDNS your traffic would probably take a loop to the “outside” just to be stopped by your router.
Does it work if you access the server with its local IP (from your local network)?
Like https://192.168.0.10:9443 ?!
I just tested something like this, here… But I used port 8080 as it is a hardware link, thus the hardware port… and of course I am doing all this inside my network
But still, I believe you just need to use the 8080 port and have it also port forwarded.
@distans, @Gunner,
Thanks for your help!!
The solution was to use the local configuration and 8080 port, as simple as that… I was blind trying to use DDNS details…
My only concern is the time it takes to update the Vpin of the other project… it takes less than 2 seconds, but as I’m running local server, those 2 seconds are a lot for me!
I’ll do more tests but the good point is that now I turn on a lamp when the door is open and turn it off when the door is closed… simple but useful!
Thanks again!!
Update:
Bad idea… now everytime I turn on the light with the original project it goes off after a few seconds due to the fact the door is closed!!!
I need to think something different… bridge should be the best option…
