Water level detection system failure
hi blynkers,
I am using water level sensor to detect the water level and when the water level goes down the motor should turn on and when that level goes up the motor should turn off but he motor keeps running continuouslyt at all time its states not changing I am using Arduino uno
#define motor 9
#define BLYNK_PRINT SwSerial
int Grove_Water_Sensor=analogRead(A0);
char auth[] = "dfe8ce156c5a4a1990fb55bb91326ded";
void sendSensor()
  Blynk.virtualWrite(A0, Grove_Water_Sensor);
void fancontrol()
  if( Grove_Water_Sensor <=256 )
      digitalWrite(motor,HIGH);
      digitalWrite(motor,LOW);
  pinMode(motor,OUTPUT);
  analogWrite(motor, 0);
  pinMode(Grove_Water_Sensor, INPUT); // The Water Sensor is an Input
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  timer.setInterval(1500L, fancontrol);
You’re not actually taking a reading from your water sensor!
This line makes me think that you’re expecting an analogue reading from your sensor, rather than just a HIGH/LOW value, in which case you’ll need to do an analogue read from the sensor and assign the result to the Grove_Water_Sensor variable.
Why are you doing both digital and analog writes to the motor pin?
thanks pete now it works
this one was by mistakes due to several experiments with both digital and analog pins
