This is a water alarm for my Air Conditioner’s 15 liters water collector canister that is needed to be manually emptied from time to time. Code can also be used as a flooding alarm system. This code checks for water every 30 seconds and turns on a led and a virtual led when water is detected. It also sends a push+email notification every 8 hours as long as water is detected.
Suggestions for improvements are welcome. Enjoy /Stefan @ stockholmviews.com
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "fake";
char pass[] = "fake-again";
const int ledPin = D5; // (WeMos)
int sensorData;
void sendAnalog()
sensorData = analogRead(A0); //reading the sensor on A0
Blynk.virtualWrite(V4, sensorData); //sending to Blynk
if (sensorData > 400) {
digitalWrite(ledPin, HIGH);
Blynk.virtualWrite(V5, 255);
}else {
digitalWrite(ledPin, LOW);
Blynk.virtualWrite(V5, 0);
void sendNotification()
if (ledPin != HIGH) {
Blynk.notify("Time to empty the water collector!");
Blynk.email("your@gmail.com", "Time to empty the water collector", "Starting to fill up!");
Blynk.email("another@gmail.com", "Time to empty the water collector", "Starting to fill up!");
// Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, "IP-address", 8080);
timer.setInterval(30000L, sendAnalog);
timer.setInterval(28800000L, sendNotification);
