I am getting this common error. Tried to find a solution, but had no luck. So please pardon me for opening a new thread for this common issue. Any clue on this please?
char auth[] = "vzcjMnE4HIwi5_9g-E3CXFD4tTJQamT0";
char ssid[] = "SLT_FIBER";
char pass[] = "****";
So, it’s not getting past the WiFi connection stage.
Both SSID and the WiFi password are case sensitive, so ensure that these are EXACTLY as they appear in your router.
If you’re using any WiFi repeaters then you may want to turn them off temporarily. If you’ve set-up MAC address filtering in your router then ensure that you add the NodeMCU’s MAC address to your whitelist.
I am 100% about the ssid and password. I checked that several times. And here I don’t have any repeaters either. And no Mac filters defined. I can connect any device to the router by entering this same password.
Can there be any issue with the NodeMCU board. I checked with another board as well and the result is same. Both the boards are cheap chinese products bought through AliExpress. Here I will attach the images of both.
