Hello
Should all Arduino variables be declared as volatile inside BLYNK_CONNECTED, BLYNK_WRITE… functions? Are these functions interupt routine or not really?
Regards
Hello
Regards
The variables in Blynk functions are not interrupt based so you shouldn’t declare them as volatile.
Are there any possible cosequences if I still declare them volatile?
Regards
No, there should be no really BAD consequences. Some sub-optimal code can be generated (but usually no issue)
