It would be really nice to have a button/widget that could set all of the virtual pins in a blynk sketch to zero- it would be nice to be able to do this from the app, but it would be nice if we could call it in our code.
My beef is that if I send a 1 / 0 over bridge every 20 seconds, and pull the plug on the controller that’s sending these values, the receiving controller can get stuck with a 1.
@zeeko@Dave1829 let’s say that, I have 2 nodemcu in the 1st one I control 4virtual and 4 physical pins beside I want to control 2nd as well like 1st one is it possible to do that. controlling 2nd one via virtual pins?
I kind of figured out a hacky way to do this for anyone that’s curious- and this is somewhat local server specific-
If you do a simple one-time for-loop in your BLYNK_CONNECTED portion of your code:
for (int i = 0; i < 100; i++) {
Blynk.virtualWrite(i,0);
You can clear out any old values stored in the server. I DEFINITELY don’t recommend doing an i from 0 to 100 on the cloud or you’ll likely get the boot.
To further elaborate on my issue, I have several controllers each linked to their own water valve. When they need water, the valve opens, and they send a 1 signal to a far away ESP. The esp is constantly adding up 1’s coming from the rooms, and if they are >0, the water PUMP turns on. If the room doesn’t need water, it sends a 0, and if all of the rooms are NOT requesting water, the pump turns off. If say, one of the rooms gets messed up, the pump might end up running for a very long time- I don’t want that.
So in my code, I have something like, if pump is running for X amount of time, run the for loop code and clear all of the values.
