Virtual pin interaction with app digital pin
With a virtual pin I want to command a digital output connected to a relay that turns a light on. When I power the board for the first time, I have to select/press the digital pin on the app where the relay is connected, then the virtual pin works fine.
In app I have two buttons: Virtual pin and Digital Pin. For the Virtual pin to work, I must press one time the digital pin, then it works OK until I power off /on the board.
Can´t find the reason why it doesn’t work from the start without pressing the digital app pin… Serial print says the virtual pin is ok, ldr values are ok…
Code explanation:
Garage light that turns on IF it is dark and door opens OR app virtual pin is enabled.
Light turns of IF it is dark (dont matter if door is open, its daytime) AND virtual pin is not selected (manual override).
Hysteresis is implemented to avoid an unstable relay switch.
The respective function is “lampadagaragem()”
Code:
#include <Ethernet.h>
#include <avr/wdt.h>         // required for watchdog timer
//counters
int i = 0;
int a = 0;
int onoff = 0;
int estadogaragem = 0;
int sensorpinogaragem = 11;
int luzgaragem = 0;
int releluz = 2;
int luminosidade = 0;
int pinoldr = 0;
int hysteresis = 20;
char auth[] = "xxx";
void heartbeatgaragem()
  onoff = !onoff;
  if (onoff == HIGH)
    Blynk.virtualWrite(5, 1023);
    Blynk.virtualWrite(5, 0);
BLYNK_WRITE(V8)
  luzgaragem = param.asInt();
void lampadagaragem ()
  luminosidade = analogRead(pinoldr);
  if (((luminosidade >= (380 + hysteresis)) && (estadogaragem == HIGH)) || (luzgaragem == HIGH))    //if ldr value is high and door is open OR virtual pin is ON
    digitalWrite(releluz, HIGH);             //relay turns light ON
  else if ((luminosidade < (380 - hysteresis)) && (luzgaragem == LOW)) //if ldr value is low AND virtual pin is LOW light turns OFF
    digitalWrite(releluz, LOW);
  else   //light turns off otherwise
void estadoatual()
   wdt_reset();
  estadogaragem = digitalRead (sensorpinogaragem);
  if (estadogaragem == HIGH)
    Blynk.virtualWrite(2, 1023);
    Blynk.virtualWrite(2, 0);
  pinMode (sensorpinogaragem, INPUT);
  pinMode (releluz, OUTPUT);
  pinMode (pinoldr, INPUT);
  wdt_enable(WDTO_8S);   //turns on watchdog timer with 8 second countdoor.  Sketch requires wtd_reset() to reset this, else a reboot is forced
  Blynk.begin(auth);
  wdt_reset(); //reset the watchdog timer in any normal op that may take time.
  i++;
  a++;
  if (a >= 10000)
    heartbeatgaragem();
    a = 0;
  if (i >= 5000)
    estadoatual();
    lampadagaragem();
    i = 0;
I believe I found another thread with the same problem, but still with no solution: Blynk defined pins are not defined until button is pressed?
No word on this? Anybody else has this problem?
Code seems ok. Could you please start from simplest sketch and move forward step by step and checking on what stage pins stop working. I think it would be the easiest way to detect exactly problem.
