Virtual pin for 4 state case, instead make virtual pin just to push state 3
Hi guys, i new in arduino and blynk, i use nodemcu esp8266, can anyone help? i want to make virtual pin just to push state 3 (case 3 //starter) in my code, i have 4 state case push with single button to on/off multiple relay, can anyone know how to insert it??
// Multiple state handling
//Version 1.00
char auth[] = "h5bh81r6leLuHbe188Zt8k0K8eKmNyF8";
char ssid[] = "RIZKY";
char pass[] = "langit123";
#define relayOFF  HIGH
#define relayON   !relayOFF
#define PUSHED    HIGH
#define relay1    D1
#define relay2    D2
#define relay3    D3
#define relay4    D5
#define capSwitch D4 //tombol  HIGH = pushed?
//when relay4Flag is true we are timing relay 4
boolean relay4Flag = false;
boolean relay1Flag = false;
boolean relay3Flag = false;
byte state      = 0;
byte buttonPoll = 0;
byte lastButtonPoll;
//timing stuff
unsigned long switchMillis;
unsigned long relay4Millis;
unsigned long relay1Millis;
unsigned long relay3Millis;
const unsigned long relay4Interval = 1000;  //one second
const unsigned long relay1Interval = 1000;  //one second
const unsigned long relay3Interval = 1000;  //one second
  pinMode(capSwitch, INPUT);  //pushed = HIGH?
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(relay3, OUTPUT);
  pinMode(relay4, OUTPUT);
  digitalWrite(relay1, relayOFF);
  digitalWrite(relay2, relayOFF);
  digitalWrite(relay3, relayOFF);
  digitalWrite(relay4, relayOFF);
} //END of setup()
  //is it time to check our switches? (every 50 millis seconds)
  if (millis() - switchMillis >= 50)
    //restart this timer
    switchMillis = millis();
    //see what's happening with our switches
    checkSwitches();
  //when we are timing relay 4, has the timer finished?
  if (relay4Flag == true && millis() - relay4Millis >= relay4Interval)
    //disable timing
    relay4Flag = false;
if (relay1Flag == true && millis() - relay1Millis >= relay1Interval)
    //disable timing
    relay1Flag = false;
    digitalWrite(relay1, relayON);
if (relay3Flag == true && millis() - relay3Millis >= relay3Interval)
    //disable timing
    relay3Flag = false;
    digitalWrite(relay3, relayON);
  //check the StateMachine
  stateMachine();
  // other none blocking code goes here
} //END of loop()
void checkSwitches()
  buttonPoll = digitalRead(capSwitch);
  //has the switch changed state?
  if (lastButtonPoll != buttonPoll)
    //update to the new state
    lastButtonPoll = buttonPoll;
    //is the switch PUSHED
    if (buttonPoll == PUSHED)
      //do nothing
    //switch has been released
      state++;
      if (state > 4)
        state = 0;
        relay1Flag = false;
        relay3Flag = false;
        //disable timing
        relay4Flag = false;
  } //END of if (lastButtonPoll != buttonPoll)
} //END of checkSwitches()
void stateMachine()
  switch (state)
    case 0:
      //do nothing
      break;
    case 1: //on
      break;
    case 2: //acc
      digitalWrite(relay2, relayON);
      break;
    case 3: //stater
      relay1Flag = true;
      relay1Millis = millis();
      //enable timing
      relay4Flag = true;
      digitalWrite(relay4, relayON);
      //start timer
      relay4Millis = millis();
      relay3Flag = true;
      relay3Millis = millis();
      state = 4;
      break;
    case 4:
      //do nothing
      break;
    default:
      break;
  } //END of switch/case
} //END of  stateMachine()
Before you do anything, you need to sort-out your void loop.
From the code below, each bottom push (after release) will increase state by 1 “state++”
At code start: state=0
One push: state=1
One push: state=2
One push: state=3
Then state will be 4 automatically: state=4
One push: state will be 5: state=5
Then state will be 0 automatically: state=0
And so on…
If you change “state++” to “state=3”
It will be as below
One push: state=3
So just change “state++” to “state=3” and try
If you can explain the logic behind this code, it will be easier to help and give you required modifications
Such as, what is connected to the 4 relays and what you want to happen when you push button.
