I am trying to make a distance measurer by using only one button. I got it working without blynk and with a physical lcd Screen and button.I have the app button set up correctly so that when I push it it returns a 0. It seems like it does not update the button state except the first time i select it. I even tried adding another buttonPin=paramAsInt(); before everytime i needed it to reread the button State. If someone could just explain how i can read the button state each time so it doesn’t get stuck in my first while loop. The problem is I don’t know how to update the Button State.
• Arduino UNO Through Serial Connection on Mac
• Ios
• Blynk server
int buttonPin;
double startTime;
double endTime;
double totalTime;
double avgTotalTime;
double bucket= 0;
double numThrows=3;
double currentEndTime;
double passingTime;
double heightMeters;
double heightFeet;
//Declare calculation constants
const double gravityMetric= 9.81;
const double gravityFeet= 32.3;
//Declare program neccesary objects
int program =0;
int selectProg=1;
String method ="Drop";
#define BLYNK_PRINT SwSerial
char auth[] = "wTmdwgVovykqSE3JhlpTMYreOJ6VstG3";
WidgetLCD lcd(V1);
BLYNK_WRITE(V2)
int buttonPin = param.asInt(); // assigning incoming value from pin V1 to a variable
if (buttonPin==1){
lcd.clear();
switch(program){
case(0)://Pick Method Drop Or Throw.
//Print options on LCD Screen while loop allows top line to stay unaltered
lcd.clear();
lcd.print(0,0,"Drop or Throw?");
while (buttonPin==1){
lcd.print(0,1," ");
lcd.print(0,1,method);
if (buttonPin==0){
if (selectProg==1){
//program=2;
method= "Throw";
selectProg=2;
delay(100);
else if (selectProg==2){
//program =3;
method= "Drop";
selectProg=1;
delay(100);
if(buttonPin==0){
program=1;
lcd.clear();
break;
break;
case(1)://Instructions for each Method and Arduino selecting proper program
lcd.clear();
lcd.print(0,0,"You've Selected");
delay(2000);
lcd.clear();
if (method== "Drop"){
lcd.print(0,0,"Push and hold ");
lcd.print(0,1,"the button until");
delay(2000);
lcd.clear();
lcd.print(0,0,"hits the ground");
lcd.print(0,1,"I'll do the Rest.");
if (method== "Throw"){
delay(3000);
lcd.clear();
lcd.print(0,0,"you catch object");
lcd.print(0,1,"Repeat 3 times");
delay(2000);
if(selectProg==2){
program=3;
if(selectProg==1){
program=2;
break;
case(2)://Drop Program
delay(5000);
lcd.clear();
lcd.print(0,0,"Ready to Drop...");
//Start Stopwatch
delay(20);
if (buttonPin==0){
startTime=millis();
//Display time passing
while (buttonPin==0){
currentEndTime=millis();
passingTime = (currentEndTime - startTime)/1000.;
lcd.print(0,1,passingTime);
lcd.print(6,1,"Sec");
//Stop Stopwatch and Calculate total time
lcd.print(11,1,"Stop");
endTime=millis();
totalTime = (endTime - startTime)/1000;
delay (1000);
lcd.clear();
lcd.print(0,0,"Total air time = ");
lcd.print(0,1,totalTime);
lcd.print(6,1," Seconds");
delay(3000);
//Uses Newtonian Kinematics[height= (1/2)*acceleration*time^2] to solve for height
heightMeters=(1./2.)*gravityMetric*totalTime*totalTime;
heightFeet=(1./2.)*gravityFeet*totalTime*totalTime;
lcd.clear();
lcd.print(0,0,"Height= ");
lcd.print(0,1,heightFeet);
lcd.print(6,1,"ft");
lcd.print(9,1,heightMeters);
lcd.print(15,1,"m");
delay(7000);
break;
//Back to start Screen
lcd.clear();
lcd.print(0,0, "Reseting...");
program=0;
method= "Drop";
bucket= 0;
selectProg=1;
delay (750);
break;
case(3)://Throw Program
delay(5000);
// Custom Function to get avg airtime of the three throws
//for loop to allow getting average
for (int j=1; j<=numThrows; j++){
lcd.clear();
lcd.print(0,0, "Ready to Drop");
lcd.print(15,0, j);
//Start StopWatch
if (buttonPin==0){
startTime=millis();
//Stop Stopwatch and calculate total time
endTime=millis();
delay (1000);
lcd.clear();
lcd.print(0,0, "Total air time = ");
delay(2000);
bucket= bucket+totalTime;
break;
avgTotalTime=bucket/numThrows;
//In this case time is cut in half because we solve for max height where Velocity=0 (y-direction)
heightMeters=(1./2.)*gravityMetric*((avgTotalTime*avgTotalTime)/4.);
heightFeet=(1./2.)*gravityFeet*((avgTotalTime*avgTotalTime/4.));
lcd.clear();
lcd.print(0,0, "Max Height= ");
lcd.print(0,1, heightFeet);
delay(7000);
//Back to Start Screen
lcd.clear();
program=0;
method= "Drop";
bucket= 0;
selectProg=1;
delay (750);
lcd.clear();
program=0;
method= "Drop";
bucket= 0;
selectProg=1;
delay (750);
break;
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
// Please use timed events when LCD printintg in void loop to avoid sending too many commands
// It will cause a FLOOD Error, and connection will be dropped
