View Second Board Blynk Bridge Virtual Pin Question
Dear all Blynk friends,
I am new and doing some project which required to used Blynk bridge to connect two Arduino-Ethernet Board.
I follow the demo code given by Blynk-Doc and it work that second board LED in Pin 9 flash every second. :slight_smile:
On the other hand, I want to view the result from Virtual Pin V5 in Second Board, but try the using demo code also not success:
BLYNK_WRITE(V5){
int pinData = param.asInt(); // pinData variable will store value that came via Bridge
Could I know which line I should insert in my Second Board (Slave) program?
#include <Ethernet.h>
char auth[] = β€œMy-Code”;
Blynk.begin(auth);
// You can also specify server.
// For more options, see Transports/Advanced/CustomEthernet example
//Blynk.begin(auth, β€œserver.org”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
My First (Master) Board Program:
char auth[] = β€œYourAuthToken”;
// Bridge widget on virtual pin 1
WidgetBridge bridge1(V1);
// Timer for blynking
static bool value = true;
void blynkAnotherDevice() // Here we will send HIGH or LOW once per second
// Send value to another device
if (value) {
bridge1.digitalWrite(9, HIGH); // Digital Pin 9 on the second board will be set HIGH
bridge1.virtualWrite(V5, 1); // Sends 1 value to BLYNK_WRITE(V5) handler on receiving side.
// Keep in mind that when performing virtualWrite with Bridge,
// second board will need to process the incoming command.
// It can be done by using this handler on the second board:
//    BLYNK_WRITE(V5){
//    int pinData = param.asInt(); // pinData variable will store value that came via Bridge
bridge1.digitalWrite(9, LOW); // Digital Pin 9 on the second board will be set LOW
bridge1.virtualWrite(V5, 0); // Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
// Toggle value
value = !value;
Blynk.begin(auth);
// Call blynkAnotherDevice every second
timer.setInterval(1000L, blynkAnotherDevice);
BLYNK_CONNECTED() {
bridge1.setAuthToken(β€œOtherAuthToken”); // Place the AuthToken of the second hardware here
Thanks in advance if someone could help.
:grinning:
Code snippets should be formatted. Please edit your initial post:
How to do that:
 ``` cpp <--put 3 backticks BEFORE your code starts  //("cpp" means C++ language)
   //Put your code here
 ``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this
//comment goes here
void helloWorld() {
   String message =  "hello" + "world";
Is there any way to detect codes automatically and format it,it can make our life simplier :slight_smile:
You can help is with developing such plugin for
discourse.org - we’d be happy to use it :wink:
