Hi, I use Blynk with esp8266 and android, since I updated blynk I have problems with the video streaming widget, my RTSP://myip:port/onvif2 link is no longer functional. I tried to install the beta version too but nothing has changed.
How can I solve it?
Sir, How to live stream on blynk app. There is no any information available on internet about this . Using cameraWebServer example in the arduino IDE i am able to live stream on any browser using the ip of ESP32-CAM . But how to live stream in blynk app . I mean in blynk app video streaming widget.
Do you mean no information other than the 50+ results you get whne you search this forum?
https://community.blynk.cc/search?q=video%20streaming%20
I’m uploading new beta version with logs - so it will possible to send logs from your app and investigate the issue. Have you also checked latest not beta release - there were some issues due to our upgrade to latest build tools for android app in previous releases, which can cause some issues as well as in video streaming.
It is connection and disconnecting in blynk app
Sometime it works well. But some time it shows this problm…
What will be the solution for this ?
I am using this code on esp32-cam ai thinker board…
https://www.dropbox.com/s/y8236clyt3pc326/Blynk_App_to_ESP32CAM_to_LINE.txt?dl=0https://www.dropbox.com/s/y8236clyt3pc326/Blynk_App_to_ESP32CAM_to_LINE.txt?dl=0
I’m having the same problem.
Do you know of a solution for when the IP works on the any browser but not on the blynk live stream widget?
Old topic eh
Blynk’s video widget is NOT a web browser, so you must have a URL that is meant specifically for streaming use. And even then it can take some trial and error to find what works best with the video widget. So no simple “solution”
