Ok, I’ve spent some time re-learning some of this stuff and ended up reinstalling the whole software suite before I could managed to compile my original code.
So now I’ve got Arduino V1.8.9, ESP Core 2.5.2 & Blynk 0.6.1
I haven’t had time to upload anything new to my Wemos board and with that core number I’m sure it probably wouldn’t work anyway, I think the previous core version was 2.3.0 but I might just try it before downgrading back to 2.3.0.
I’ve got another board at my office and a BME280 so maybe I’ll recompile with that one to save breaking my operational board which is ok other than it crashes every few days.
The chap that was previously helping me did create another version of the code with the additional parts to check for internet connection and reboot if not available, I never tested this and it does not have the code for the temp sensor but I’ll post it here in case its any use.
#define BLYNK_PRINT Serial //Jue
#include <ESP8266WiFi.h> //Jue
#include <BlynkSimpleEsp8266.h> //Jue
char auth[] = ""; //Jue
char ssid[] = ""; //Jue
char pass[] = ""; //Jue
SoftwareSerial Victron(D7,D8); // RX, TX //Jue changed this
WidgetLED led1(V6);
char p_buffer[80];
#define P(str) (strcpy_P(p_buffer, PSTR(str)), p_buffer)
char c;
String V_buffer; // Buffer to hold data from the Victron monitor
float Current;
float Voltage;
float SOC;
float CE;
String stringOne;
// Connect to WiFi network
Serial.println();
Serial.println();
Serial.println(ssid);
WiFi.begin(ssid, pass);
delay(500);
Serial.print(".");
Serial.println("");
Serial.begin(19200);
Victron.begin(19200);
Blynk.begin(auth, ssid, pass); //Jue
readVictronData(); // This will initially set Victron variables
timer.setInterval(5000, sendDatatoBlynk); // Send Data to blynk every 5 sec
// Main void loop that will continously be running
if (WiFi.status() != WL_CONNECTED) { // If wifi is not connected run reconnect() function
reconnect();
if (Blynk.connected()) { // Checking Blynk connection. If connected...
led1.on(); // Turn on Virtual LED in app
Blynk.run(); // Run Blynk
readVictronData(); // Read Victron Data
timer.run(); // Will make sure sendDatatoBlynk is called
Serial.println("Whoops blynk is not connected need to do something about that");
led1.off(); // Turn of LED in app if connection to blynk is down
CheckBlynkConnection(); // If Blynk connection is down, this will be called, should reconnect
void reconnect() {
Serial.print("Reconnecting");
WiFi.mode(WIFI_STA);
delay(500);
Serial.print("."); // As long as it is trying to connect print a . each 500ms to debugger
Serial.println("");
Serial.println("WiFi re-connected");
void sendDatatoBlynk() {
// These if statements make sure only to send data if data has been set in the main loop already
Serial.println("I am called within sendDatatoBlynk function");
if(Current){
Blynk.virtualWrite (V2,Current);
if(Voltage){
Blynk.virtualWrite (V1,Voltage);
if(SOC){
Blynk.virtualWrite (V4,SOC);
if(CE){
Blynk.virtualWrite (V3,CE);
void readVictronData() {
if (Victron.available()) {
c = Victron.read();
if (V_buffer.length() <32) {
V_buffer += c;
if (c == '\n') { // New line.
if (V_buffer.startsWith("I")) {
String temp_string = V_buffer.substring(V_buffer.indexOf("\t")+1);
double temp_int = temp_string.toInt();
Current = (float) temp_int/1000;
if (V_buffer.startsWith("V")) {
int temp_int = temp_string.toInt();
Voltage = (float) temp_int/1000;
if (V_buffer.startsWith("SOC")) {
SOC = (float) temp_int/10;
if (V_buffer.startsWith("CE")) {
CE = (float) temp_int/1000;
V_buffer=""; // Empty V_Buffer
} else { // If Victron not available reset software
Serial.println("Reset..");
ESP.restart();
void CheckBlynkConnection(){ // check if connected to Blynk server
if(!Blynk.connected()){
Serial.println("Not connected to Blynk server");
Blynk.connect(); // try to connect to server with default timeout
else{
Serial.println("Connected to Blynk server");
