I was developing a new dashboard and wondering why I was losing loads of power then I realised when I purchase Value M or Value L widgets they cost 400 power but if I delete them I only get 200 power I had done this multiple times so its cost me over 1000 power, is it correct ?
Other than the fact that I have hemoriged power, if I purchase a Labeled Value L widget it costs 400 power if I then touch the widget I see in the to right of the screen +200 also if I choose the widget to get at the setting screen and scroll to the bottom I see red box with Delete and below this +200
400 energy is returned anyway.
It’s just a bug in the label. We will fix it in next release.
For sure only 200 power was being returned I tested it several times to be sure before my first post, however now when I try it I get 400 so I guess you must have fixed the problem … Thanks …
