Continuing the discussion from New Android Release 2.0.0:
Getting Error Message on 2nd Device
“Error processing client command”
On widget:
- Value Display
- Labeled value
Button and LED working just fine…
On widget:
Could you please give us more details. What is your setup and when do you get this message? Do you use cloud server?
Yes I’m using cloud server, curently the problem only happen when the Value Display widget is beeing used to display Analog Pin A0 (Node MCU), other value working fine.
Considered solved.
