V2.0 Map Widget
In the legacy app, I was able to set coordinates and add a string on top of the markers. In the new product, the documentation only mentions coordinates but nothing about the string. Does this mean there is no way to add a string or is it simply lacking in the documents?
Thank you
yep just lack of documentation I have it working exactly how it was with string in the legacy app
@nathan027 Thanks very much
@nathan027 did you change your code at all between the legacy product and the new version? I am missing something because the pin drops work just fine in legacy but the same code is not dropping pins in the new version of Blynk.
Thank you
yep i just used this
Blynk.virtualWrite(V20,1,myString1,myString2,β€œtag”);
