Using the Uno wifi serial 1 library with Blynk
Not if you gave all of your money to the Apple store already!
Mega is good because it has more Serials.
For my main project I need more pins then an esp8266 has, and 2 analogs and a stable PWM. And if the sketch is for Atmega, I can still switch from WiFi to Ethernet.
And do not forget that esp8266 was designed for serial WiFi modules and they used gpio pins of Tensilica for the system and for the system boot setup. So many of the ā€˜free’ pins require some state at boot.
