Using SPI with arduino MEGA 2560 to communicate with ENC28J60 and MAX6675
Hi PeteKnight thank you to answer, yes it is correct they are connected to the same PIN because they use SPI communication where you only need to hace one different PIN (CS) that is set to LOW when the module wants to communicate with the arduino (this peace of code is in the libraries that use SPI).
