Using 3 Blynk Sliders to control 3 climate-related relays
I’m not quite sure what’s wrong with my code, but I have 3 Blynk sliders, a humidity/temp sensor and a CO2 sensor. I’m using the slider values as the settings- if the real values go below those settings, I want my relays to turn on (with a little bit of delay so the motors don’t burn out). For some reason, I can only get the humidity relay to turn on with this code. Can anyone see some issues? And I’m also not quite sure where the best place to put my sensorReadings (for example, float h = myClimate.readHumidity():wink: to save the most space on the project.
Any thoughts?
#include <Bridge.h>
#include <BlynkSimpleYun.h>
#include <Wire.h>
#include "SparkFunHTU21D.h"
#include "kSeries.h"
HTU21D myClimate;
kSeries K_30(8, 9); //CO2 Read
unsigned long currentMillis=millis();
unsigned long interval=5000;  // the time we need to wait
unsigned long previousMillis=0; // millis() returns an unsigned long.
int tempSlider;
int co2Slider;
int humdSlider;
int lightSlider;
float t;
float h;
float co2;
int tempRelay = 10;
int co2Relay = 7;
int lightRelay = 4;
int humdRelay = 5;
//Blynk token
char auth[] = "b828e244f8b94392af33e13c346a4244";
  Blynk.begin(auth);
  myClimate.begin();
  pinMode(tempRelay,OUTPUT);
  pinMode(co2Relay,OUTPUT);
  pinMode(lightRelay,OUTPUT);
  digitalWrite(lightRelay,LOW);
  pinMode(humdRelay,OUTPUT);
//Climate Display..........................................................
//Display CO2 Values on V Pin 5
BLYNK_READ(5) {
unsigned long currentMillis = millis();
const long interval=2000;
if (currentMillis - previousMillis >= interval) {
  float setting = K_30.getCO2('p');
  co2 = setting;
  Blynk.virtualWrite(5,co2);
//Display HTU Temperature Values on V Pin 5
BLYNK_READ(0) {  // temp display
  float celsiusTemp = myClimate.readTemperature();
  celsiusTemp = (celsiusTemp * 9.0)/ 5.0 + 32.0; //convert to fahrenheit
  t = celsiusTemp;
  Blynk.virtualWrite(0,t);
//Display HTU Humidity Values on V Pin 1
BLYNK_READ(1) {  //Humidity Display
  float h = myClimate.readHumidity();
  Blynk.virtualWrite(1,h);
//Climate Slider Settings....................................
//Temperature Setting in Blynk on Virtual Pin 2
BLYNK_WRITE(2) {
  int tempSetting = param.asInt();
  tempSlider = tempSetting;
  if (currentMillis - previousMillis >= interval){
      if (t < tempSlider) {
        digitalWrite(tempRelay, HIGH);
  if (t >= tempSlider) {
    digitalWrite(tempRelay,LOW);
//Humidity Setting in Blynk on Virtual Pin 3
BLYNK_WRITE(3) {
  int humdSetting = param.asInt();
  humdSlider = humdSetting;
      if (h < humdSlider) {
        digitalWrite(humdRelay, HIGH);
  if (h >= humdSlider) {
    digitalWrite(humdRelay,LOW);
//Co2 Setting in Blynk on Virtual Pin 4
BLYNK_WRITE(4) {
  int co2Setting = param.asInt();
  co2Slider = co2Setting;
      if (co2 < co2Slider) {
        digitalWrite(co2Relay, HIGH);
  if (co2 >= co2Slider) {
    digitalWrite(co2Relay,LOW);
I dont know so much about code but I should have change humdRelay to other Relay and see if humdity can turn on other Relay, to verify that the Relay is working.
    digitalWrite(**tempRelay**, HIGH);
digitalWrite(**tempRelay**,LOW);
Also use humdSlider in CO2 setup to verify that CO2 code is working
  if (h < **humdSlider**) {
if (h >= **humdSlider**) {
@zeeko It seems you are thinking in wrong direction. Those code above is very wrong. You could do it much simpler. Just example of how you should implement what you want:
int tempSlider = 30;
void ssetup() {
 timer.setInterval(5000L, checkTemp);
BLYNK_WRITE(2) {
tempSlider = param.asInt();
void checkTemp() {
        digitalWrite(tempRelay, LOW);
