Board info: Arduino Nano 33 IOT
I keep getting the user_interface error when compiling my code under the edgent 8266 sketch.
I have tried to create an header file with that name and still doesn’t work. I have tried a different company and still faced with the same issue.
My arduino IDE is 1.8.15
Blynk 1.01
I don’t know what I am doing wrong here please help.
Dipothomas:
Arduino Nano 33 IOT
Dipothomas:
edgent 8266 sketch
The Nano 33 IOT isn’t an ESP8266 based board, so that’s probably the cause of the error message.
Thank you Pete for your prompt reply as usual. Below is the error I am currently getting when I use ESP32.
#include <WiFiClientSecure.h>
compilation terminated.
The Nano 33 IOT isn’t an ESP32 either!
John93
September 1, 2021, 3:37pm
5
Hey there.
Are you choosing the right board and the right com port just like the image ?
Thank you John93. I am. Here is my screenshot.
John93
September 1, 2021, 4:18pm
7
Can you show me your sketch ?
I am using the Blynk Edgent sketch. It has multiple header files. This is the Edgent_ESP32.ino. Let me know if you want the content of all the header files as well.
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
#include "BlynkEdgent.h"
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
John93
September 1, 2021, 5:04pm
9
Okay.
First go to blynk / blynk.edgent and choose edgent_MKR1000 not edgent_ESP32
Second they will ask you to download some libraries ( if not already installed ) just download them and everything should work just fine.
It errored on header file BlynkEdgent.h.
Sketch:
void app_loop();
void restartMCU();
#include "Settings.h"
#include <WiFi101.h>
#define BLYNK_SEND_ATOMIC
//#define BLYNK_USE_SSL
#include <Blynk.h>
#include <Adapters/BlynkWiFiCommon.h>
WiFiSSLClient _blynkWifiClient;
//WiFiClient _blynkWifiClient;
BlynkArduinoClient _blynkTransport(_blynkWifiClient);
BlynkWifiCommon Blynk(_blynkTransport);
#include <BlynkWidgets.h>
#ifndef BLYNK_NEW_LIBRARY
#error "Old version of Blynk library is in use. Please replace it with the new one."
#endif
#if !defined(BLYNK_TEMPLATE_ID) || !defined(BLYNK_DEVICE_NAME)
#error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
#endif
#include "BlynkState.h"
#include "ConfigStore.h"
#include "ResetButton.h"
#include "ConfigMode.h"
#include "Indicator.h"
#include "OTA.h"
#include "Console.h"
inline
void BlynkState::set(State m) {
if (state != m && m < MODE_MAX_VALUE) {
DEBUG_PRINT(String(StateStr[state]) + " => " + StateStr[m]);
state = m;
// You can put your state handling here,
// i.e. implement custom indication
void printDeviceBanner()
Blynk.printBanner();
DEBUG_PRINT("--------------------------");
DEBUG_PRINT(String("Product: ") + BLYNK_DEVICE_NAME);
DEBUG_PRINT(String("Firmware: ") + BLYNK_FIRMWARE_VERSION " (build " __DATE__ " " __TIME__ ")");
if (configStore.getFlag(CONFIG_FLAG_VALID)) {
DEBUG_PRINT(String("Token: ...") + (configStore.cloudToken+28));
DEBUG_PRINT(String("Device: ") + BLYNK_INFO_DEVICE);
DEBUG_PRINT(String("WiFi FW: ") + WiFi.firmwareVersion());
void runBlynkWithChecks() {
if (BlynkState::get() == MODE_RUNNING) {
if (!Blynk.connected()) {
if (WiFi.status() == WL_CONNECTED) {
BlynkState::set(MODE_CONNECTING_CLOUD);
BlynkState::set(MODE_CONNECTING_NET);
class Edgent {
public:
void begin()
// Required to get MAC
WiFi.begin();
indicator_init();
button_init();
config_init();
console_init();
printDeviceBanner();
} else if (config_load_blnkopt()) {
DEBUG_PRINT("Firmware is preprovisioned");
BlynkState::set(MODE_WAIT_CONFIG);
void run() {
app_loop();
switch (BlynkState::get()) {
case MODE_WAIT_CONFIG:
case MODE_CONFIGURING: enterConfigMode(); break;
case MODE_CONNECTING_NET: enterConnectNet(); break;
case MODE_CONNECTING_CLOUD: enterConnectCloud(); break;
case MODE_RUNNING: runBlynkWithChecks(); break;
case MODE_OTA_UPGRADE: enterOTA(); break;
case MODE_SWITCH_TO_STA: enterSwitchToSTA(); break;
case MODE_RESET_CONFIG: enterResetConfig(); break;
default: enterError(); break;
Edgent BlynkEdgent;
BlynkTimer edgentTimer;
void app_loop() {
edgentTimer.run();
edgentConsole.run();
Error Code:
```#include <WiFi101.h>
exit status 1
WiFi101.h: No such file or directory
Screenshot:
[image|690x270](upload://vEVe1QQbrL7auSkRkQcdtOLahYr.png)
John93
September 1, 2021, 5:22pm
11
I’m sorry choose MKR_1010 not MKR1000
Got hit by another error:
BlynkEdgent.h:9:10: fatal error: WiFiNINA.h: No such file or directory
#include <WiFiNINA.h>
John93
September 1, 2021, 5:29pm
13
Download wifinina library, timer5 library and ArduinoOTA library.
John93:
ArduinoOTA library
I have successfully installed those libraries.
John93
September 1, 2021, 5:32pm
15
Now try to upload the sketch
After I ran it, the error went away and now, I am being confronted with another error:
#include <FlashStorage.h>
FlashStorage.h: No such file or directory
I dont have EEPROM feature on my board, should I still proceed?
Wow! Wow! Wow! Thank you, Thank you so very much John93. You are AMAZING. I most deeply appreciate your patience and your guidance.
I am able to compile my code successfully and also able to see my board SSID when I scanned for it.
