Hello Friends,
This is my first post and I am new learner on BLYNK platform
I worked on a reference code of WiFi credential, and developed code for setting WiFi credential using onboard push button and webpage as well as wiping WiFi credential using long press same push button for nodeMCU (esp devices) and blynk platform
/*Procedure
- Load attached code with proper blynk generated Authentication token
- LED at D0 starts blinking, which indicates nodeMCU is not connected to WiFi
- Connect D3 for 5 sec to ground for wiping old SSID and password (optional for first time)
- Short press(2sec) D3 pin to ground and then make it open again or HIGH
- You will see OnDemandAP device in available wifi devices list in smartphone
- Select âOnDemandAPâ device
- You will get IP address of 192.168.4.1 in serial monitor or you can check in smartphone also
- Open 192.168.4.1 webpage and set your wifi credential
- Then restart nodemcu again(Optional)
- If nodeMCU connect to WiFI then D0 led will continuously glow
- observe serial monitor for these above mentioned step
//needed library for on Demand WiFi setting
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#define TRIGGER_PIN 0 //D3 pin for user defined wifi setting, active HIGH at beginning of the program
Do not use for onDemandwifi setting
char ssid[] = "User";
char pass[] = "Pass";
int onDemandIndicator= D0; // wifi indicator blinking LED
char auth[] = "Auth";// You should get Auth Token in the Blynk App.
void wifiMysetting(){
WiFiManager wifiManager;
if ( digitalRead(TRIGGER_PIN) == LOW ) {
delay(5000); //Long press D3 button for wiping WiFi setting
wifiManager.resetSettings();
while (WiFi.status() != WL_CONNECTED){
Serial.println(".");
Serial.println("On demand wifi setting");
digitalWrite(onDemandIndicator,LOW); //blinking led
delay(200);
digitalWrite(onDemandIndicator,HIGH); // blinking led
delay(500);
// is configuration portal requested?
//WiFiManager
//Local initialization. Once its business is done, there is no need to keep it around
//WiFiManager wifiManager; //uncomment this if it is not declaring at other place
if (!wifiManager.startConfigPortal("OnDemandAP")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("connected...yeey :)");
delay(200);
//////////////////////////////////end ondemand code////////////
void setup(){
pinMode(onDemandIndicator,OUTPUT);
pinMode(TRIGGER_PIN, INPUT); //user defined wifi pi active high during power on
Serial.begin(115200); //need for OnDemandWifi_for good result
wifiMysetting(); //check wifi status and call on demand wifi setting function
//Blynk.begin(auth, ssid, pass); //do not use for OnDemandWifi setting
// WiFi.begin(ssid, pass); //do not use for OnDemandWifi setting
Blynk.config(auth); // in place of Blynk.begin(auth, ssid, pass);
Blynk.connect(10000); // timeout set to 10 seconds and then continue without Blynk
// Wait until connected
void loop(){
BLYNK_WRITE(V1){
//int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
int inX=param[0].asInt(); // joystick on V1 pin with merge mode
int inY=param[1].asInt(); // joystick on V1 pin with merge mode
Serial.print("incoming X =");
Serial.println(inX);
Serial.print("incoming Y =");
Serial.println(inY);
