Useing the SparkCorePolledTimer with photon
hello.
am using photon and i cant use the simpletimer
so as i read in the documents that i have to use the SparkCorePolledTimer.
but my q is
this code is for arduino ,so am gunna replace the simpletimer with SparkCorePolledTimer,what about the
timer.setInterval(3000, CheckButton); // check button state every 3 second?? and
timer.run();>???
do i need to change them also to make it work ???
what should i write instead of them ??
thank u
// add all the normal Blynk stuff depending on your hardware setup
byte val = 0; // variable to store the button status
byte buttonD5 = 5; // button / switch on digital pin 5
byte led = 2; // the pin that the LED is atteched to, digital pin 2
pinMode(led, OUTPUT); // initalize LED as an output
pinMode(buttonD5, INPUT); // initialize button / switch as an input
void CheckButton(){ // done every 3 seconds
byte val = digitalRead(buttonD5); // read button value
if (val == HIGH) { // check if the sensor is HIGH
Blynk.virtualWrite(V3, 255); // turn app LED on V3 ON
else {
Blynk.virtualWrite(V3, 0); // turn app LED on V3 OFF
Blynk.run(); // need all the regular Blynk stuff in definitions and setup
please edit your post, using the code formatting button, so we can see your code.
  else {
}`indent preformatted text by 4 spaces`
