Use webhook to PUT data to google sheets?
I’ve just started using Blynk, but I am unclear on how Webhook works. Can I send push data from the hardware directly to a URL, or does it have to go to the App first?
I’ve been using ESP8266 to send data to Pushingbox as a GET http request, which in turn sends the data to Google Forms as a GET https request. The data is then automatically added to a Google Sheet. I’d like to be able to simplify this and send data directly from hardware to Google Forms via URL. Can data to be pushed to my Google Sheets without having to go through the App?
@hungrybeagle Yes. Did you read docs regarding webhook?
If you sent direct from the hardware it wouldn’t be using Blynk’s Webhook widget.
Your Pushingbox reference is probably similar to the Zapier system mentioned in this thread i.e. data gets into Google Sheet via a 3rd party (4th party if you count Blynk as the 3rd party).
I have a Blynk project that sends data directly to Google Sheets with and without the Webhook widget.
See details in this thread starting at Use webhook to PUT data to google sheets? - #62 by Costas
I did, that’s why I was wondering if it was possible to send data direct from hardware to URL because from what I was reading, I didn’t see it explicitly stated that it was possible but wondered if there was some way to do so.
@Costas should be fixed. Let me know if not.
@Dmytro just sent 15 or 16 sets of data to Google sheets from my Webhook button and your server doesn’t look to have blocked me for spamming so all looks good. You might want to check the logs at your side to be sure.
Is there any way for Blynkers to build the server jar from the master branch (Studio to jar?) so we can check logs at our side before you push each release of the server?
No need for manual build. You can change property in server.properties :
Log debug level. Possible values: trace|debug|info|error. Defines how precise logging will be. From left to right → maximum logging to minimum
log.level=trace
I meant for the “302” fix.
@Costas Hello all,
I am the author of the HTTPSRedirect library. In case you have any questions, please check out the github page and open a new “issue” there. I have also launched version 2 of the library. Please see the readme for the details and use this only in future projects. I’ll plot free heap and stack from ESP8266 in Google Sheets.
Coming up: a more featured and simpler interface into Google sheets for more devices or general linux scripts running on something like Raspberry Pi, Particle, etc.
Thanks.
github: http://bit.ly/1SopEug
