I want to trigger some events when I switch between tab´s
Is it possible to trigger a virtual pin when I switch between my different tabs ?
No. Tabs widget is pure client interface widget and shouldn’t affect hardware state. Take a look at Menu widget.
I kow.
This is the reason I posted it under ideas.
At my project I want to use some hardware modules with identical functionality ( for example 4 Wemos D1 mini)
For each of the HW modules I will provide a tab to display some data and information.
And I want to flash a LED at the hardware module which I selected via tab.
It should be automatic selected emediately if I select the tab.
I need this too.
