Hello Blynk team, community-
I searched the community if there was any help on how to set Property of the Super Chart Data Stream variables. I did not find any so asking for help. If this was addressed, I must have missed it, pls point me to the thread.
Can I set the Min/ Max/ Suffix type properties of a data stream from the hardware side? Example would be able to allow the user the set the max Y axis value in the app using a Step Setting Widget, then read that value and then set the Max value of the Data Stream property in the Super Chart?
Example will be similar of how I can set the color of a slider widget using, {Blynk.setProperty(V0, “color”, “#0C990C”);}
I would like to do {Blynk.setProperty(V1, “SUPERCHART.MAX”, “200”);}
Hope this makes sense. Any suggestions?
Thanks.
